Re: global variables and autonomous independent
how do I read the analog slider? is it a .vi or something?
On the left side of the Autonomous, it calls Get Analog Input.vi. This returns the four sliders from the screen on the DS. If you plug in the I/O board, the board sets the sliders, not the screen.
Greg McKaskle |
okay I connected the analog one slot on the get analog in.vi to a case structure surrounding the autonomous code. So now I can just set the slider on the little laptop they sent us and it will convert that to different cases right?
Test it and see.
Greg McKaskle |
Also check out the "Get Alliance" vi which outputs field position.
I might be mistaken, but I thought that that Get Alliance only shows your DRIVER STATION position, not necessarily your field position.
#7
That is correct. Other than telling you whether you are on the red team or the blue team, Get Alliance does NOT tell you anything about your field position.
| Autonomous Independent Code Issue Watchdog not fed | pilum40 | FRC Control System | 0 | 11-02-2010 12:00 |
| Using Sensors in Autonomous Independent | Felipe Sagui | NI LabVIEW | 2 | 27-01-2009 17:25 |
| Making global variables in LabVIEW. | Joshamuffin | National Instruments LabVIEW and Data Acquisition | 1 | 19-01-2009 13:35 |
| HELP!!! Counters, global variables, and the like | danielkitchener | Programming | 2 | 23-02-2004 23:53 |
| Global Variables, anyone? | Darkman_X000 | Programming | 3 | 05-02-2004 22:11 |
