Go to Post Because FIRST wants everyone to have a sense of accomplishment even if you didn't accomplish anything during the match. - Koko Ed [more]
Unread 13-02-2010, 13:43
Team1710's Avatar
Team1710 Team1710 is offline
FRC #1710
Team1710 is an unknown quantity at this point
Toggle through button?
We are having some trouble with storing variables. We would like to create some code that when you press a button and then release the button, we can toggle a t/f or change a variable. For example, switch between the numbers 1, 2, and 3 by hitting a button. The problem we've run into is getting the number to stay once the button has been released. As soon as the button goes back to false, the toggle goes back to default...
Unread 13-02-2010, 13:50
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Re: Toggle through button?
Depending on what language you're using, and assuming that we're using Java and joystick button 2, the code would look something like:
if joystick.getButton(2) == true && number < 2 {
     number++
} else if joystick.getButton(2) == true && number == 2 {
     number = 0
Note - this code is untested. Be sure to declare "number" and set it to 0 earlier in the program.
Also, this code will use values 0, 1, and 2, rotating each time the button is pressed.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 13-02-2010, 14:12
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
I don't know how the Java code handles the button calls, but wouldn't that just cycle through the numbers without stopping? Unless getButton removes the read value when you read it the first time, this would set one number one loop, and see that the button is still pressed in the next loop and set the next number. You need a second variable to hold the last read button value. In the same Java code, it would look like this:
if joystick.getButton(2)==true && number<2 && lastState==false {
     number++
} else if joystick.getButton(2)==true && number==2 && lastState==false {
     number = 0
   lastState=joystick.getButton(2);
Since lastState is set after the if() structure, the new value will not be read until the next run through. So if it's FALSE now and you push the button, it will increment the variable, then set lastState to TRUE, which will be read the next time, and the structure will not run. Then, when you release the button, it sets lastState to FALSE again, and you can increment the variable again.
You can also use a shorter code system utilizing modulus. Modulus (%) reports the remainder in a division. So, 5 % 3 = 2. This will only report the values 0 (divisible by 3), 1 (1 more than a factor of 3) and 2 (2 more than a factor of 3). This will allow you to use a slightly longer equation, but shorter code which might actually run a bit faster (however insignificant with a 400Mhz processor):
if joystick.getButton(2) == true && lastState == false {
     number = (number+1) % 3;
   lastState = joystick.getButton(2);
Good luck, and let us know if you have any more problems.
Unread 13-02-2010, 14:14
Lead Programmer
AKA: Socks
@Daltore: You're probably right, I didn't think of that.
Unread 13-02-2010, 14:34
Team1710's Avatar
FRC #1710
We aren't in java, i forgot to mention we are in Labview...
Unread 13-02-2010, 23:13
daltore's Avatar
AKA: Aaron Osmer
Okay, so the setup for LabView will be the same as in Java, you need to variables. In LabView, variables are just read/write calls to indicators and controls. Create two indicators or controls on the front panel (one boolean, one numeric). Then go to the block diagram, right-click, and go to the Structures pallet. There will be a gray box near the bottom that says "LOCAL". Click this and place it on the block diagram. It will have a question mark and a pin on the left. Click the question mark, and it will show a list of indicators and controls that currently exist in that VI. Select your boolean or numeric. To change the variable to read instead of write, right-click on the variable, and select "Change to Read". This will allow you to input and output data from the controls and indicators in your VI more than once.
However, since LabView is by nature a parallel language, we need a way of doing the increment and setting the last seen variable separately. To do this, you can use either a Flat Sequence Structure or a Stacked Sequence Structure (both in the structures pallet). A Flat Sequence structure looks like a film reel, and each frame is executed one after another, from left to right. To add a frame, right click on the right edge of the structure and select "Add Frame After". In the first frame, you need to have an AND operator (boolean pallet), a NOT operator on the lastSeen variable to negate its value (also boolean pallet), a Quotient and Remainder VI (numeric pallet, I think), and a case statement. The Quotient and Remainder VI works just like the "%" modulus symbol in the Java example, you plug in "number + 1" into X and "3" into Y, and the remainder appears on the top right corner (R, for "remainder). Wire that to your "number" variable.
In the next frame, you need to set "lastSeen" (or whatever you called your boolean variable) to the joystick button value.
That should be it, let me know if you want me to explain anything further.
Unread 14-02-2010, 00:35
exprg:melonhead's Avatar
exprg:melonhead exprg:melonhead is offline
The Teamless/ Travelling Mentor
AKA: Justin Sticht
FRC #3278 (Qwerty)
exprg:melonhead has a spectacular aura aboutexprg:melonhead has a spectacular aura aboutexprg:melonhead has a spectacular aura about
http://frcmastery.com/try-me/state-machines/
this may actually be able to explain it better than any of us can. this is the clean way of doing that
Unread 14-02-2010, 00:52
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Originally Posted by daltore View Post
In LabView, variables are just read/write calls to indicators and controls...
You could just use a Shift Register or Feedback Node, that seems like the simplest thing to do. Add a feedback node, set the input (bottom terminal) to what you want it to start as, then when you set it set the right terminal and that data will be available to the left terminal when you next run the loop.
Kettering Motorsports
Unread 14-02-2010, 01:10
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Yep. In labview, a true/false structure that increments or decrements the number, along with an in-range check to keep it within the numbers you want and a feedback node to return the last value. The only hitch is that you will need to code a trigger-style VI that latches until it sees the button released so it won't count up if it loops several times during a single button press.
Unread 15-02-2010, 18:10
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
The LabVIEW key word is
uninitialized shift register
Omar
Labview toggle switch GunfighterJ NI LabVIEW 8 13-02-2011 18:03
can you use a single button as a toggle? woogit General Forum 1 15-02-2008 14:21
toggle switch Windward Programming 31 27-01-2006 22:38
Code: Toggle on Tap Dave Scheck Programming 0 11-02-2005 18:07
Toggle? f22flyboy Programming 5 03-11-2002 08:03
