#20
Re: solenoid with compressor vi
The problem can be with the Pressure Switch or the code.
One test is to unplug the pressure switch while the compressor is running. If the Relay light goes out, then you have a bad pressure switch. If the Relay keeps going green, then I'd suspect a code problem.Since the Spike is doing what the Digital Sidecar Relay LEDs are doing, then the wiring for that is working fine. |
| Solenoid Wiring and Compressor Help | BurtGummer | Electrical | 16 | 17-02-2010 14:25 |
| How to program solenoid and compressor? | Jason F | Java | 8 | 08-02-2010 15:15 |
| 1482 Help with Compressor | Rinaldi 427 | General Forum | 7 | 31-01-2007 07:46 |
| Help With Compressor Code | fred | Programming | 6 | 21-01-2005 17:40 |
| Problem with compressor | Nick R. | Pneumatics | 3 | 21-02-2003 10:51 |
