Go to Post But sometimes you just wanna build something that's MFD. - Andrew Schreiber [more]
Unread 13-02-2010, 13:42
m-boyer's Avatar
m-boyer m-boyer is offline
FRC #2753
Team Role: Electrical
m-boyer is an unknown quantity at this point
Victor 884 PWM problem
Hey everybody!
We have a fisher-price motor hooked up to a victor 884. Everytime we turn on the robot it starts flashing orange, meaning that there is no PWM signal. We've tried different PWM cables, switched connections in the Victors and in the DSC, used a different battery, different Victors, different positions on the PD board, and it STILL flashes orange.
Any ideas? The programmer claims that it's not a programming problem, but does it sound like one?
My apologies if this post has already been made somewhere else.
Unread 13-02-2010, 14:20
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Re: Victor 884 PWM problem
Try flipping the PWM cable around. I've only gotten them right on the first try vey recently...
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 13-02-2010, 14:22
electron's Avatar
electron electron is offline
Former Team Overdrive member
AKA: Joseph
FTC #2753 (Team Overdrive)
electron is just really niceelectron is just really niceelectron is just really niceelectron is just really nice
I'm the other electronics guy for 2753, and We have already tried both ways.
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
I may be one of the few people that has moved from FRC to FTC, and enjoyed it
Unread 13-02-2010, 14:43
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
If you tried both ways I would suggest looking into the pwm connecter part of the victor and then figuring out where the 3 pins should align in there because from trial and error I had I figured out that I had 2 pins in but not all three because of how big the hole for the connector was. Do you get it?
Unread 13-02-2010, 14:53
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
If you are using LabView, take a look at your code. Make sure that you have set that PWM port to "Victor" and not "Jaguar".
That would be the next most likely culprit.
Can you also post some pictures of your setup for us to attempt to troubleshoot the problem? Makes it easier if we know what we are working with.
Unread 13-02-2010, 16:16
Ramiro_T's Avatar
Ramiro_T Ramiro_T is offline
Technical Specialist
AKA: Ramiro Trejo
no team (n/a)
Team Role: Student
Ramiro_T is an unknown quantity at this point
Why don't you try bending the pins on you pwm cable so it will make a tight fit on the connector. And remember to plug your pwm right. The Victors have connectors that have a stubborn mind of its own.
Unread 13-02-2010, 23:41
It can be quite difficult to get a PWM cable to seat properly into a Victor 884. I suspect that is the problem. You can prove it's not a software issue by plugging a jaguar into the same PWM cable.
Unread 14-02-2010, 09:00
fsgond's Avatar
fsgond fsgond is offline
Why aren't you throwing balls?!
AKA: Anthony
FRC #5484 (Memento Vitam)
fsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant futurefsgond has a brilliant future
In the past I have removed the pins and shaved down the plastic. This allows the connector to go in further and make the connection.
Unread 14-02-2010, 09:09
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
On our test robot we had one channel to a Jag suddenly stop working. It turned out the cable between the cRIO digital module and the DSC had become slightly askew. Other PWM channels both before and after it on the DSC worked fine. You may want to check the cable is still fully seated. (especially if your robot has been going over the bumps at high speed )
Unread 14-02-2010, 12:35
There were two threaded standoffs for the Digital Sidecar in the Kit of Parts (top of page 14 of the checklist). They are there to let you connect the 37-pin cable firmly.
Unread 14-02-2010, 16:26
electron's Avatar
AKA: Joseph
Thanks everyone for the speedy replies!
just to let you all know that it was mostly a programming problem, but neither the programmers nor the electricians are exactly sure what it is.
but it does work now.
Victor 884 Devo1098 Electrical 6 29-06-2007 07:51
Victor 884 problem Gal Longin Control System 11 26-01-2005 00:47
Victor 884 problem Gal Longin Electrical 11 26-01-2005 00:47
Victor and PWM Cable Problem RIgnazio Electrical 2 13-01-2005 23:02
Victor 884 Kevin Ray General Forum 25 28-01-2003 15:02
