Go to Post As far as we know, FIRST could replace football by 2018! - Adam Richards [more]
Unread 13-02-2010, 14:20
sunit sunit is offline
FRC #1504
sunit is an unknown quantity at this point
Re: Cannot connect Windriver to robot
If the windows firewall is running on your WinDriver PC, disable it and retry. Also make sure that you have the correct team number defined in WindRiver:
Windows -> Preferences -> FIRST download preferences
- Sunit
Unread 14-02-2010, 00:17
cmh0114 cmh0114 is offline
AKA: Cam H
FRC #0217 (Thunderchickens)
cmh0114 will become famous soon enoughcmh0114 will become famous soon enough
I can't get the video to run on my computer, so sorry if I mention something that you're already doing...
Make sure you have the IP addresses set up correctly and that there are no IP conflicts on your network. If you're in an area with a wireless network, disable your laptop's wireless adapter to avoid interference. Like sunit said, make sure your firewall is disabled - you shouldn't be connected to the Internet at this point anyways.
Once that's done, make sure you set the correct .out file for your project.
I'm not sure what the first error is caused by, but the second error sounds like your wireless bridge on your bot either isn't booting correctly or isn't booting at all. If you have another bridge, test that to see if it works. You should also try connecting with the Classmate, just to make sure it's not some obscure setting on your PC. And try lengthening the timeout period to some crazy long time so that you absolutely know that it's not connecting, as opposed to it starting to connect but then timing out.
Unread 15-02-2010, 09:34
abpahl abpahl is offline
FRC #3407
abpahl is an unknown quantity at this point
Tried all these things, no luck. Tried disabling the firewall, made sure I had the correct team number, etc. Also, as far as I can tell, all ips are set correctly, no conflicts (robot set to 10.34.7.2, classmate to 10.34.7.5, development laptop set to 10.34.7.6)
We have the default code downloaded to the robot, we got help from another team. But, now we can't download any new code due to this error. The default program can be run by the Classmate with the driver station.
EDIT: Ok, re-imaged the crio, to see if that would help. It didn't, but it has a new error message. The first error message is the same, but now the second one is:
Error connecting to 'VxWorks6x_10.34.7.2'(Registry localhost). Failed to launch target server
Possibly caused by: Target Server died unexpectedly during start up with exit code '0'..
Removed dead entry from Registry!
SECOND EDIT: The probelm has mysteriously disappeared. Glad it works, thanks for everyone's help.
Unread 19-02-2010, 08:28
AKA: Cam H
Sometimes restarting WindRiver, the robot, and/or the computer will fix the problem. If it happens to you again, try to find out what fixed it. Fear Murphy's Law and prevent it by knowing exactly how to fix anything that goes wrong.
But hey, congrats! Good luck with the rest of your code!
Cannot connect to cRIO from WindRiver Darkknight512 C/C++ 8 25-01-2011 19:42
Cannot connect to cRIO aybose Java 3 02-02-2010 22:20
I/O Board Cannot Connect Haragorn FRC Control System 2 14-01-2010 13:50
Cannot connect to the Real-time target Mr. E FRC Control System 13 02-02-2009 20:47
Cannot Connect to Axis Camera Wirelessly computerish Technical Discussion 4 11-01-2009 19:19
