Go to Post I hope Dave doesn't see these. He'll want you to put in a banana and use it for a game clue. - IndySam [more]
Unread 13-02-2010, 00:51
DWirth DWirth is offline
FRC #2509
DWirth is an unknown quantity at this point
I Button Press, Always True Until Next Press
Hello,
I am programming 2 pneumatic cylinders to push something up and keep it up. However the way I have it now, you would have to hold the button down to keep the 2 valves the correct boolean value.
I want the button on the joystick to be pressed once then stay true until I press the button again which would turn it back to true. This thing I would want to turn to true of false is a case structure.
Does anyone have any ideas on how I would achieve something like this, I'm out of ideas. Any help would be awesome.
Thanks again,
Dillon Wirth
Unread 13-02-2010, 01:36
Electrical Engineer
Rookie Year: 1995
Re: I Button Press, Always True Until Next Press
Originally Posted by DWirth View Post
Hello,
Thanks again,
Dillon Wirth
Dillon,
Read through this thread. Your answer may lie within...
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 13-02-2010, 16:47
Egg 3141592654's Avatar
Egg 3141592654 Egg 3141592654 is offline
Now a mentor, always a student
FRC #0810 (Mechanical Bulls)
Egg 3141592654 is on a distinguished road
Feedback loop is the best way to go. The help in the Labview Help library will explain more in depth.
"The answers to the book of life are not found in the back." Charlie Brown
Software Mentor - Team Apex Robotics 5803
Lead Programmer - Team 810 Mechanical Bulls '09-'11
Joystick Button Press dboisvert C/C++ 6 07-03-2009 11:09
Arbor Press RMS11 Technical Discussion 11 14-08-2008 23:41
Intelitek Loader Press PRGM Button Fail ttldomination VEX 1 25-02-2008 19:36
press fitting crazy_ratchet Technical Discussion 7 08-12-2003 18:03
Can a student Coach press the Stop Button archiver 2001 3 24-06-2002 02:39
