Go to Post Don't date anyone on your team unless you are POSITVE that you will be able to handle yourself professionally, not only during your relationship, but even after it ends. - Jaine Perotti [more]
Unread 13-02-2010, 14:02
Yppiz's Avatar
Yppiz Yppiz is offline
FRC #1014 (Bad Robots)
Rookie Year: 1776
Yppiz is an unknown quantity at this point
Exclamation Front panel indicator
Is there a way to change what is visible on a front panel while a VI is running?
For example, if you have a camera image on the screen, can you design the program to hide the image and then make a larger image visible?
A quick reply would be very helpful.
Thanks!
My friend VICTOR has a JAGUAR and a 2CAN, and from his Lab'sVIEW he can CRIO grande. Do the puns have you VEXed? You're not the FIRST.
Unread 13-02-2010, 14:37
Re: Front panel indicator
There are several ways. You can put stuff in to a tab control and change which tab is shown either with the mouse or programmatically. You can also use property nodes, but the tab is easier.
Greg McKaskle
Unread 13-02-2010, 15:20
Yppiz's Avatar
Rookie Year: 1776
When I run my program, the wondow is way to big. How do I shrink it?
Unread 13-02-2010, 18:56
Shrink it using the mouse and save it. A more precise method is to use the VI Properties dialog>>Window Size settings. The default is 1024 by 400. If you want to see code that moves and changes windows settings, that is on the default dashboard. It is the True code that responds to the UserName == Driver test.
Greg McKaskle
Unread 13-02-2010, 22:49
ecnahc515 ecnahc515 is offline
FRC #3192
ecnahc515 is an unknown quantity at this point
You can edit the type def that lets you choose between what resolution of what you want, and then you can add it to the case and have it actually change the size in there.
Unread 15-02-2010, 18:44
Yppiz's Avatar
Rookie Year: 1776
Talking Re: Front panel indicator
Thanks!
Classmate PC - Front Panel jmanela NI LabVIEW 28 23-08-2009 20:36
Indicator light cables? AlexD744 Electrical 6 15-02-2009 20:47
pic: Team 810's Robot - Front Panel LetsGo810 Extra Discussion 2 30-01-2007 10:31
DC Voltage indicator Don Wright General Forum 5 09-09-2005 07:52
OI indicator questions PyroPhin Technical Discussion 3 15-02-2002 08:53
