Go to Post everybody wants a piece of success! - Taylor [more]
Unread 13-02-2010, 16:47
z.s.tar.gz z.s.tar.gz is offline
FRC #3242
z.s.tar.gz is an unknown quantity at this point
Can not connect to cRIO
We are trying to run the sample robot code, but we keep getting this:
Error connecting to 'VxWorks6x_10.32.42.2' (Registry localhost). Failed to launch target server
Possible casused by: back-end not connected
Remove dead entry from registry!
What could be causing this?
Unread 13-02-2010, 17:41
Chasegd128 Chasegd128 is offline
FRC #0128
Chasegd128 is an unknown quantity at this point
Re: Can not connect to cRIO
We had the same problem. We re-imaged the cRIO and it then decided to work. So your best bet would be to re-image it. Good luck!
Unread 13-02-2010, 19:06
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
are you physically connected to the robot?
good battery?
correct network settings?
there are probably more reasons this could come up, but those are the three most common
Watchdog.Kill();
Cannot connect to cRIO from WindRiver Darkknight512 C/C++ 8 25-01-2011 19:42
Any way to connect to console on cRIO? SteveGarward C/C++ 10 05-02-2010 07:28
Cannot connect to cRIO aybose Java 3 02-02-2010 22:20
cRIO Does Not Communicate, Yet Can Be Pinged and Re-Imaged 1951-44U FRC Control System 7 15-12-2009 21:25
Can not connect bridge and router wirelessly team877 Programming 4 08-01-2009 00:18
