Go to Post Is it January yet?? - Kevin Kolodziej [more]
Unread 13-02-2010, 19:20
Re: Editing 'Set Speed' on the dashboard
You cannot send data from dashboard back to the robot. That is a one-way trip.
You can send values from the driver station I/O tab. The four compatibility sliders can be set by HW such as pots if you connect the I/O board to the DS, or you can set them onscreen by dragging.
Scale them up or down a bit, and you have a Speed Setting.
If you only want to do this for debugging, what Mark pointed out is one of the major debugging features. Instead of using a constant, make the value a control on the panel. Run using the arrow, open the panel, and change the number whenever you like. Once you know what the number needs to be, you can make it a constant, or keep it a control and make sure to set the current value default using the control popup.
Greg McKaskle
Unread 13-02-2010, 22:52
ecnahc515 ecnahc515 is offline
FRC #3192
ecnahc515 is an unknown quantity at this point
Make a numeric control on the front panel of the teleop VI. And in the block diagram you can have it multiply the x and y values by the control.
Just set the control min and max to be between 0 and 1. So then when the control on the front panel is half way your motors will go half the speed. Basically makes a throttle.
How to set up custom dashboard for auto start Kevka Programming 11 28-01-2010 18:46
Setting speed values for a set more block (was: Hi) team877 NI LabVIEW 2 15-02-2009 18:32
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
How do you set a speed limit on the servo Fares Programming 6 01-01-2003 15:04
