Go to Post With FIRST, its all about style! In the northeast, we are alllll style. - Andy Grady [more]
Unread 13-02-2010, 19:44
Re: Can't get cRIO to connect to Driver Station Software
The cRIO needs be v19 or v20, depending on which update you have.
Communications is a summary of the others. If the only thing you are missing is code, I'd open the dev tool, setup the sample project or even an example, and run. Be sure to leave the DS on and running so that you can enable the robot once you have code.
Greg McKaskle
Unread 13-02-2010, 22:33
greatman05 greatman05 is offline
AKA: Chavez Clemons Jr.
FRC #2224 (Phoenix Phenoms)
greatman05 is an unknown quantity at this point
Send a message via AIM to greatman05 Send a message via MSN to greatman05 Send a message via Yahoo to greatman05
OK...By the way, here's another question: During the flashing process, is it normal for the robot to disconnect and reconnect a couple of times?
By that second part, do you mean to download the default code and run it, and then try to enable it through the driver station?
Also, when I hooked up the Analog Breakout and the other breakout (default is slot 2), I got a red light under "Robot" in Diagnostics when it usually was green. How do I fix that?
Driver station can't find io module remulasce FRC Control System 2 25-01-2010 01:24
Can't connect your imaging tool to the cRIO? jman1783 Control System 0 24-01-2010 14:07
Wireless Router to Connect with Driver Station Happyisgood FRC Control System 15 04-09-2009 00:02
Can't change team # (was: Driver Station problem) Lilszamora FRC Control System 2 03-02-2009 16:26
cant get NXT to connect to controller station via bluetooth cougarbotics FIRST Tech Challenge 5 04-12-2008 00:19
