Go to Post 22 motors? Challenge Accepted. - gyroscopeRaptor [more]
Unread 08-02-2010, 18:59
kennypu kennypu is offline
FRC #2467
kennypu is an unknown quantity at this point
absolute minimum for displaying image on dashboard
Hey,
I was going to finally try and see if I can get some image showing from the camera, and I was wondering, what do I basicly need for the absolute minimum to show the image on the dashboard? So if I were to just copy paste code from the 2010 vision sample, what would I copy paste into my own program to get the images showing? Thanks in advance.
Unread 08-02-2010, 19:36
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: absolute minimum for displaying image on dashboard
Calling "AxisCamera::GetInstance();" starts up the task that broadcasts the video to the Dashboard. Put that anywhere in your code and it should run.
Unread 08-02-2010, 20:19
FRC #2467
really? Thats all you need? I was expecting more. I'm assuming that that is merely just to show the camera images, and to actually set exposure, etc. we have to create an axis camera object first? Thank you though, That would be a lot simpler than what I was trying to do.
Unread 08-02-2010, 20:32
AKA: Ian Thompson
The return from that function is an AxisCamera& object, so you want to just use that for the object. Anything that has a GetInstance function should never be created by a user program. Always call GetInstance to create your copy of the object
Unread 09-02-2010, 03:58
Teh1337Bix's Avatar
Teh1337Bix Teh1337Bix is offline
None #3132
Teh1337Bix is an unknown quantity at this point
Anyone sure this works?
Yes I'm Aussie, and yes I ride a kangaroo to school.
Yeah bruduz!!!
Unread 09-02-2010, 19:12
FRC #2467
I tried it and no results yet. My DS is updated, and camera should be set correctly.
Unread 09-02-2010, 20:30
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
You can also use PCVideoServer (you'll need to include a file, I think its "Vision\PCVideoServer.h")
class robotclass : ....
    PCVideoServer pcvs;
public:
    robotclass:
       ,pcvs()
Watchdog.Kill();
Unread 09-02-2010, 21:47
AKA: Ian Thompson
Check the console for errors. If the camera is called for an init before the camera is fully booted then the vision code crashes.
Unread 10-02-2010, 09:33
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
    PCVideoServer pcvs;
public:
    robotclass:
       ,pcvs()
A quick note on PCVideoServer:
My team found out the hard way that the camera, when initialized with GetInstance(), starts its own PCVideoServer. Attempting to start a second one blocks the entire thread indefinitely.
Unread 10-02-2010, 13:35
Kohala2460's Avatar
Kohala2460 Kohala2460 is offline
AKA: Michael
FRC #2460 (Na Paniolo)
Kohala2460 is an unknown quantity at this point
Would the GetInstance(); function be included in the wpilib1764 or do i need to download the Workbench Software update from http://first.wpi.edu/FRC/frccupdates.html
Thankyou, Hopefully can get this going before competition
Unread 10-02-2010, 14:45
FRC #2467
when the axis camera has a solid green ring, that means its fully initialized correct? It is always like that so I'm assuming that the initialization is not the problem. I will check the errors though.
EDIT:
I still cannot get the camera to work. first of all, is it possible to access the camera through browser (192.168.0.90) if its connected to the cRIO, and classmate connected to cRIO through the wireless bridge?
secondly, when the cRIO and axis cam is connected, I don't see any activity in the ethernet port. The bridge's port shows the green and orange LEDs going wild, but for the axis cam, there is no light at all. Is this normal? or should there be some type of activity.
Unread 10-02-2010, 23:17
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
Team 3132 got the camera working last night.
We had gone and changed the IP address of the camera by mistake to the 10. subnet, so the code couldn't communicate with the camera. After resetting the camera IP address, and with the FRC user account configured (with password FRC) it worked with the following line put in our robot class constructor:
AxisCamera &myCamera = AxisCamera::getInstance();
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 13-02-2010, 20:34
FRC #2467
hmm..I still can't get the camera working. Rather, now I'm getting the 'watch dog not fed' message in the DS. Does anybody have a suggestion? I have set up the camera, my DS is up-to-date, the only thing I havn't done is the recent update of the workbench, but I am sure that is not necessary as that is for the DS LCD.
Here is my code btw:
#include "WPILib.h"
#include "Vision/AxisCamera2010.h"
#include "Vision/HSLImage.h"
#include "PIDController.h"
#include "Gyro.h"
#include "Target.h"
#include "DashboardDataSender.h"
//#define MINIMUM_SCORE 0.01
 * This is a demo program showing the use of the RobotBase class.
 * The SimpleRobot class is the base of a robot application that will automatically call your
 * Autonomous and OperatorControl methods at the right time as controlled by the switches on
 * the driver station or the field controls.
bool moveState = false;
class RobotDemo : public SimpleRobot
	RobotDrive myRobot; // robot drive system
	Joystick stick; // only joystick
	Jaguar leftMotors;
	Jaguar rightMotors;
	Compressor *m_com;
	//DashboardDataSender *dds;
	//Gyro *gyro;
	//PIDOutput *pidOutput;
public:
	RobotDemo(void):
		myRobot(3, 4),	// these must be initialized in the same order
		stick(1),		// as they are declared above.
		leftMotors(1),
		rightMotors(2)
		m_com = new Compressor(4,2);
		AxisCamera &camera = AxisCamera::getInstance();
		//dds = new DashboardDataSender();
		//gyro = new Gyro(1);
		//pidOutput = new SamplePIDOutput(myRobot);
		GetWatchdog().SetExpiration(0.1);
	 * Drive left & right motors for 2 seconds then stop
	void Autonomous(void)
		GetWatchdog().SetEnabled(false);
		myRobot.Drive(0.5, 0.0); 	// drive forwards half speed
		Wait(2.0); 				//    for 2 seconds
		myRobot.Drive(0.0, 0.0); 	// stop robot
	 * Runs the motors with arcade steering.
	void OperatorControl(void)
		GetWatchdog().SetEnabled(true);
		while (IsOperatorControl())
			GetWatchdog().Feed();
			//myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick)
			if(stick.GetRawButton(1))
				moveState = 0;
			if(stick.GetRawButton(3))
				moveState = 1;
			if(moveState == false)
				//do nothing
			if(moveState == true)
				leftMotors.Set(-stick.GetY());
				rightMotors.Set(stick.GetZ());
				Wait(0.005);
			// Create and set up a camera instance. first wait for the camera to start
					// if the robot was just powered on. This gives the camera time to boot.
					//Wait(10.0);
					//printf("Getting camera instance\n");
START_ROBOT_CLASS(RobotDemo);
any body see any problems?
Unread 13-02-2010, 20:40
byteit101's Avatar
EDIT:
1. no, the eth ports cannot access each other directly
2. no, there should be some activity
Watchdog.Kill();
Unread 13-02-2010, 20:51
FRC #2467
thank you for the clarification byteit101.
hmm...Thats interesting then, Why won't the camera connect to the cRIO? I know its not a dead port, because I they both flash when the robot first starts up. However after that there is no activity. Does any body know why?
Displaying Camera Image in C# Dashboard PranavSathy C/C++ 12 08-02-2010 17:06
Labview Dashboard not displaying camera. GunfighterJ NI LabVIEW 1 02-02-2010 19:20
Reinstall of dashboard doesn't fix camera image streaming ellisk Programming 2 20-01-2010 08:04
Absolute beginner looking for resources saberflare General Forum 3 16-11-2007 10:35
Minimum Gauge Wire for Sensors? psquared89 Electrical 2 05-02-2006 15:26
