Go to Post Meh, wear safety glasses. - Mike Schreiber [more]
Unread 11-02-2010, 18:06
TheDominis TheDominis is offline
FRC #2152
TheDominis has a spectacular aura aboutTheDominis has a spectacular aura about
Simple Custom Video Dashboard 30+ FPS
I've made a dashboard in C# that uses the stock camera code. I get 30 FPS with their newest code.
I've attached the executable and source code.
Requirements
.NET 4.0 Framework
How To Use
Set the drop down list to Tcp as that is currently the only supported format.
Set the text box with "Robot IP Goes Here" to your robot's IP.
Notes
It will take about three seconds to show video.
Unread 12-02-2010, 06:17
PranavSathy PranavSathy is offline
Team Captain
AKA: Pranav Sathyanarayanan
FRC #0263 (Sachem Aftershock)
PranavSathy is an unknown quantity at this point
Re: Simple Custom Video Dashboard 30+ FPS
Thank you very much, that code was very useful, but just a few questions, first, why would you use XAML and not a regular windows form, second what is the reason for 2 classes, you can just put the content of Reciever in TcpListener and just use the thread within TcpListener itself.
I hope you dont mind if I use your code in my own program with many modifications , I willll be sure to release it with credit .
Unread 12-02-2010, 07:17
FRC #2152
I'm using Wpf which requires Xaml. Wpf is supposed to be hardware accelerated by direct 2D.
I split up the recievers because I also had a Udp receiver and I still may add that.
Unread 12-02-2010, 16:44
Team Captain
Thanks for the reply, I dont think you want to add a UDP reciever because UDP is prohibited during matches, the block the network (UDP network), or atleast I heard so. They use UDP to switch Autonomous from OperatorControl and so they dont want any UDP traffic other than their own.
Unread 12-02-2010, 16:55
FRC #2152
I know I made a UDP video server and the GDC said it was illegal.
Unread 12-02-2010, 17:07
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
It's still useful if you want to read userdata sent from the cRIO to a custom dashboard. That data is sent over UDP as part of the "official" communications protocol.
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 12-02-2010, 19:06
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
Can you please post a Ubuntu-Mono friendly version?
Unread 13-02-2010, 08:04
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
why it is using .Net 4? I like to try to make my programs use .net 2 for greatest compatibility. You can use 3.0 for WPF
Watchdog.Kill();
Unread 13-02-2010, 08:45
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Seriously???
Great program! Works really well for the COMETS!
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 13-02-2010, 13:30
1 * 4 != 14
deleted
Unread 13-02-2010, 14:42
FRC #2152
I don't know what version of .NET the computer came with so I installed 4.0. I believe that the computer I tested it on only has 3.5, but I am not sure.
Unread 13-02-2010, 18:15
Team Captain
He is probably using Visual Studio 2010 like me, its default configuration is to make .NET 4.0 applications, but there is an option during the Project Wizard on which .NET to use, as low as 2.0 or 1.0 I believe, but I forget .
Unread 13-02-2010, 18:40
1 * 4 != 14
can you please post a version that is compatible with mono?
Unread 13-02-2010, 18:55
byteit101's Avatar
although I applaud your open-sourceness, Mono has no (current) desire to implement WPF (http://mono-project.com/WPF), so you would have to do a lot of work
Watchdog.Kill();
Unread 13-02-2010, 21:20
FRC #2152
I've commented the code. I'm just slightly confused as to why you want to run it on Ubuntu especially since we all got tiny little 2Go computers with XP.
How to set up custom dashboard for auto start Kevka Programming 11 28-01-2010 18:46
Custom Dashboard writchie FRC Control System 7 02-03-2009 20:21
Custom Dashboard - Visual Basic Mike Lat Programming 3 23-01-2005 14:26
Custom Dashboard Executable ready for Download! archiver 2001 1 24-06-2002 01:01
Custom dashboard program available. Interest? archiver 2001 4 24-06-2002 00:45
