Re: 2=0
to put it simple.... 2 is the new 0, or the other way around
Re: 2=0
Using complex mathematics not yet known to man, I have come up with the following theory:
The bird is greater or equal to the word. But seriously, I'll believe that 2=0 when I type 2 in my calculator and it says 0. You guys think to hard! |
Re: 2=0
Don't always believe your calculator. Sometimes they lie.
Re: 2=0
Re: 2=0
Nice trick. Of course, anyone looking at the results for 1782^12 + 1841^12 and 1922^12 individually will think that it breaks Fermat's theorem, but entering (1782^12) + (1841^12) - (1922^12) shows that the two sides are not in fact equal. If you could just find values of a, b, and c so that their difference is greater than 12 decimal points away, however, I think that the calculator would fall for the trick because of rounding problems due to memory issues. At least it would work in Matlab, and I'm guessing the calculator stores data the same way.
So, anyone know some a, b, and c such that (c^n)/((a^n)+(b^n)-(c^n)) > 1*(10^13) ? Did I even do that right? |
Re: 2=0
If you are adding like this,
.5 + .5 + .5 + .5 = 2 Etc, then you are really doing a Sigma(2/n) for n times as n approaches infinity. Using the distributive property this sigma expression can be written: n * (2 / n ) = 2 For all nonzero real numbers, this expression equals 2. At n = 0, there's a hole in the graph, yet its limit is 2. The key about infinity and zero is that they are not well-defined. It depends HOW you're reaching infinity or zero, not only the fact that you are. |
#7
Re: 2=0
Or in wikiwords [citation needed] |
#8
Re: 2=0
Yeah that's true.
I was just trying to say that approaching 0 or inf from different curves/functions changes the behavior when you perform operations between them. Like how y = x and y = e^x both approach inf as x -> inf yet they do so at different "rates." e^x is much "faster" than x so, x/e^x has a limit of 0, whereas e^x/x has a limit of inf as x --> inf. This is related to L'Hopitals rule, and is sorta what his rule is doing by taking the derivatives of top and bottom of the fraction etc etc. |
#9
Re: 2=0
But from a ref's point of view, 1=2
b=a then "Multiply by (a)" ab=a2 (can't make squared symbol) then "Subtract (b2)" ab-b2=a2-b2 then "Factor" b(a-b)=(a+b)(a-b) then "Divide by (a-b)" b=(a+b) then "Say it ain’t so" 1=2 |
#10
Re: 2=0
I know this one. But I won't give the answer away to those who don't.
![]() Last edited by Norman J : 29-04-2010 at 20:18. |
#11
Re: 2=0
It would of have been easier for me to figure out if he had stated that a=1 and b=1...I got it now though. Hint: Try substituting 1's in. Although you don't have to use 1's it is the only way to get 1=2 otherwise you get 2=4 or 4=8 etc...
#12
Re: 2=0
and also....if 1=2 then doesn't 2=4? :-) |
