Go to Post "Greatness isn't achieved by doing the uncommon things but instead by doing the common things uncommonly well." - Wayne C. [more]
Unread 11-02-2010, 20:57
Rafael Vasquez Rafael Vasquez is offline
FRC #1245
Rafael Vasquez is an unknown quantity at this point
Communication issues
This one has really been baffling us. Quite often when we attempt to connect to the bot using the DS for testing and code deployment, we are able to connect to the Gaming Adapter onboard the bot, but not to the cRIO. It seems to happen randomly, which to me suggests a weak connection between the gaming adapter and the cRIO.
However, our electrical team assures us that the cable we are using and the connectors are good, so I'm posting this issue anyway. Could it be anything besides the cable or connectors, and if so, what would the issue be and how can we fix it?
Unread 11-02-2010, 20:59
EthanMiller EthanMiller is offline
Lead Programmer
AKA: Socks
FTC #4356 (The Zip Ties)
EthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura aboutEthanMiller has a spectacular aura about
Re: Communication issues
Is the gaming adapter plugged into the cRIO port 1 or 2, and is it a standard CAT5 cable?
It should be in port 1, and it should NOT be crossover.
When all else fails, read the manual.
FRC 1713 K Island Gears 2009, 2010 (Not 2011 due to budget, hopefully 2012!) - Fingerlakes Regional
FTC 4356 The Zip Ties 2010-2011 Season - NNYRC (2010 9th seed).
Unread 11-02-2010, 21:15
ISGOI Howie ISGOI Howie is offline
FRC #2996
ISGOI Howie is an unknown quantity at this point
try makeing sure everything is connected to the router then reste the router(power off for 15 sec) for some reason any device that is connected to the linksys router doesnt work right if it isnt connected when the router boots... thats what gave us troubles at least
Unread 12-02-2010, 07:43
There's a known issue on a cold powerup. Sometimes the WGA takes longer to boot than the cRIO. If the cRIO finishes its network configuration before the WGA is ready to look for network activity, some routing information doesn't get set and the link to the robot doesn't get established. (There is not yet a software update to work around this.)
If this happens again, reset the cRIO only (there's a tiny reset button near the serial port) without removing power. The WGA will already be operating and the network configuration will succeed.
If that doesn't fix it, you probably do have either an intermittent connection or a faulty WGA.
Unread 13-02-2010, 13:15
FRC #1245
Thanks for the help. I'll make sure that everyone on my team knows this in case it comes up.
Unread 13-02-2010, 23:28
The new DS update that was just posted should work around this issue: http://joule.ni.com/nidu/cds/view/p/lang/en/id/1535
Unread 14-02-2010, 00:02
exprg:melonhead's Avatar
exprg:melonhead exprg:melonhead is offline
The Teamless/ Travelling Mentor
AKA: Justin Sticht
FRC #3278 (Qwerty)
exprg:melonhead has a spectacular aura aboutexprg:melonhead has a spectacular aura aboutexprg:melonhead has a spectacular aura about
we also found out that you need to update not only the drivers station, but a new labview from this week. worked for our similar problem
Using non KOP router, possible cause of wireless communication issues? saba Programming 10 31-01-2010 13:22
team communication Barak_BN Rules/Strategy 2 08-02-2009 13:20
Communication devices Daniel_LaFleur General Forum 3 05-01-2009 18:05
2 way IR communication? neilcooper Control System 4 09-01-2008 20:14
Section 2 - Communication team222badbrad General Forum 2 08-01-2004 20:03
