Go to Post Who would think 130 points would be a losing score! - Chris Fultz [more]
Unread 13-02-2010, 14:51
mrbob1000's Avatar
mrbob1000 mrbob1000 is offline
I feel smarter already!
AKA: Stephen Johnston
FRC #2377 (CCompany)
mrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to behold
Send a message via AIM to mrbob1000
Lead allowed?
Is lead considered a hazardous substance if it is fully contained within aluminum tubing?
Unread 13-02-2010, 16:50
lbarger's Avatar
lbarger lbarger is offline
Senior LRI NC District
AKA: Lee Barger
FRC #0587 (The Hedgehogs)
lbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud of
Re: Lead allowed?
Lead is hazardous to handle without proper safety equipment. While it may be 'safe' when fully contained, the process containing it will pose a hazard to you and your team mates. While you may sneak it past an inspector at competition, I would recommend against it.
If this is for ballast or mass, there are other dense metals that will be nearly as effective without the safety concerns of lead such as stainless and standard steels and some copper alloys such as brass and bronze.
A free online resource for searching materials based on specific properties is www.matls.com.
Unread 13-02-2010, 16:57
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Lead allowed?
Al (a lead inspector) posted this last year: "Lead in any form must be sealed (painted, coated or dipped) and may not be machined in the pit."
Thread here: http://www.chiefdelphi.com/forums/sh...ad.php?t=76636
If it's fully contained it should be OK. You need to be careful when handling it at home, especially if you're doing any drilling or machining on it.
Keep in mind, though, that the only authoritative source of answers is the official Q&A at forums.usfirst.org. Nothing posted on CD, no matter who wrote it, will work as a defense if you get questioned by an inspector.
Unread 13-02-2010, 16:59
imp's Avatar
imp imp is offline
FRC #0675 (Tech High Phantom Robotics)
Team Role: Animator
imp is on a distinguished road
Re: Lead allowed?
You can use Bismuth instead of lead. It is almost exactly the same just less hazardous.
Unread 13-02-2010, 20:13
mrbob1000's Avatar
Re: Lead allowed?
Thank you for the information, i now feel much more confident in my teams usage of lead.
Unread 14-02-2010, 00:42
travis travis is offline
FRC #2091
travis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of light
Re: Lead allowed?
Pb? HAH! Only the bumpkinest of rubes go to Plumbum (specific gravity=11) for density -- it's just half that of the high end stuff and has dismal physical properties.
It is some kind of cruel joke that Earth didn't get more Pt. Even with the high density (SG=21), if it were more abundant they would probably make turbine compressor vanes out of it. You can boil Pt under pure oxygen and it will never react, all with better strength than Ti (pffft SG=5). Best of all, your friendly inspector could file it into powder and make a healthful beverage from it. Several rappers and I even have teeth made from the stuff. You can have about 2.5 Oz and still be under the cost limit.
Someone out there sells depleted U (SG=19) counterweights for the aircraft industry and unitednuclear.com gets a hunk now and then. Non radioactive U is still chemically poisonous though. The IAEC will send inspectors to your school should you amass more than 15 lbs of it.
I spent months tracking down a guy in Sweden to sell me a used Ta (SG=17) sputtering target to make my wedding ring from. Polished Ta is like looking into the cosmos; there is nothing like it. A W/Re (SG~=20) alloy ended up on my finger for various reasons, but I will trade a size 9 Ta ring for a Haas tool room milling machine with full software upgrades and will throw in the Ta remnants for a 6" Kurt vise.
As so often is the case, none of the really cool stuff is a viable option, but you are in luck. Your local expensive outdoor store should have W (SG=19), both in the form of fishing weights and bird shot, for about 10X what they charge for Pb. Forget about the inspectors, call a tooling manufacturer if you figure out how to machine W in the pits. There have been more studies linking Al (SG=a paltry 3) to heath problems than W, so you could leave it uncoated and in the open.
Unread 14-02-2010, 11:59
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: Lead allowed?
If lead must be coverd, contained, or painted what happens when you soder ends together?
Every day is a new adventure!!!
Unread 14-02-2010, 13:53
Re: Lead allowed?
Ends of what? Wire? If you choose to use leaded solder for some reason, then you break out the electrical tape afterwards and wrap that connection solidly.
Unread 14-02-2010, 15:27
Dick Linn's Avatar
no team (Synergy)
Re: Lead allowed?
Tungsten is pretty dense stuff. Even Tungsten Carbide isn't bad. If you can find scrap electrodes from TIG welders or get scrap carbide mills and inserts from a machine shop they would work OK if you can pack them closely. Most recent price I saw for Tungsten shot was $24./lb. Scrap carbide tooling is maybe $8./lb.
Tantalum inlay rings: http://www.ringworksstudio.com/Pages...ack-Rings.html
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 14-02-2010, 15:37
AKA: Dr. Brooks
no team (WRRF)
Re: Lead allowed?
If you are going to use tungsten electrodes,
make sure that you don't use the thoriated
ones. They are radioactive.
We like to use gold paint on lead to make it safe.
Eugene
Kit Lead Screw OD ? de_ Kit & Additional Hardware 2 14-03-2009 14:59
How to lead a team GillSt.Bernards General Forum 22 16-02-2009 00:43
Lead-Lag Compensator eSouL Control System 0 13-08-2004 03:21
Eating lead in 2000 archiver 1999 24 23-06-2002 23:07
Lead Screw Nut archiver 2000 1 23-06-2002 22:49
