Go to Post It definitely looked like a penalty, but in FRC if it looks like a penalty and smells like a penalty, well, unfortunately it might not be. - Basel A [more]
Unread 02-14-2010, 08:06 AM
omalleyj omalleyj is offline
AKA: Jim O'Malley
FRC #1279 (Cold Fusion)
omalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to beholdomalleyj is a splendid one to behold
Re: Autonomous 2010 FRC
The lower level stuff is called from Java by methods that are just wrappers for the call to the real functions (ala what JNI gives you) which I assume are written in C or LabView and are sitting in a .so somewhere. If you look in the NIVision class you will see what I mean, for instance MeasureParticle calls imaqMeasureParticle. I am not sure what is available in LabView so I don't know what percentage of functionality is exposed to Java, but everything to do ball detection is certainly there, and you can use the higher level methods in ColorImage and MonoImage.
<ideasrule>
I don't see any particle filter, thresholding functionality, or shape detection (except for ellipse detect) functionality. Where are they?
Not sure exactly what you are looking for here, the particle reports in the demo are filtered by user written code that compares the information returned to what is expected and generates a number that is compared to a threshold value. But I don't get the feeling that is what you mean.
Are you looking to detect the edges yourself?
FRC 2010 Team Update #5 Alex Cormier General Forum 23 01-27-2010 01:05 PM
Sample 2010 C++ Program's Autonomous Not Won't Run joxphoto General Forum 2 01-25-2010 01:30 PM
2010 FRC Kickoff Workshops Mark McLeod FIRST E-Mail Blast Archive 3 01-07-2010 10:23 AM
NASA FRC grants 2009-2010 ?? Andrew Schuetze Fundraising 18 10-02-2009 01:56 PM
FRC Java 2010 Documentation alivemyst Java 11 09-07-2009 07:03 PM
