Go to Post You do realize that you all started jumping to conclusions without asking first which JVN he was talking about. - Jay H 237 [more]
Unread 14-02-2010, 02:44
odel's Avatar
odel odel is offline
FRC #2990 (Hotwire Robotics)
odel is an unknown quantity at this point
Send a message via Yahoo to odel
Motor Code Help
Hi, I would like to do something like:
Joystick1yaxis = Motor[1];
Joystick1yaxis = Motor[2];
Joystick2yaxis = Motor[3];
Joystick2yaxis = Motor[4];
how would I go about this?
Thanks
Unread 14-02-2010, 10:22
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Motor Code Help
have you read http://first.wpi.edu/Images/CMS/Firs...artedWithC.pdf and http://first.wpi.edu/Images/CMS/Firs...sers_Guide.pdf?
I would assume you want something more like this:
robotDrive.TankDrive(stick1,stick2);
Watchdog.Kill();
Unread 14-02-2010, 13:56
odel's Avatar
Re: Motor Code Help
But I need two joysticks running 4 motors, 2 motors to each joystick.
Unread 14-02-2010, 14:46
buddyb's Avatar
buddyb buddyb is offline
FRC #1885 (ILITE)
buddyb has a spectacular aura aboutbuddyb has a spectacular aura aboutbuddyb has a spectacular aura about
Re: Motor Code Help
Like ByteIt said, you'll want to do robotDrive.TankDrive(leftJoystick, rightJoystick);
But, the constructor you'll want to use is:
RobotDrive(SpeedController *frontLeftMotor, SpeedController *rearLeftMotor, SpeedController *frontRightMotor, SpeedController *rearRightMotor, float sensitivity=0.5)
This will give you tank drive for 4 motors from two joysticks.
Good luck!
FRC - Team 1885 - Programmer.
Unread 14-02-2010, 14:55
odel's Avatar
Re: Motor Code Help
So now I have:
class RobotDemo : public SimpleRobot
	Jaguar frontLeftMotor(1);
	RobotDrive drivetrain(SpeedController *frontLeftMotor, SpeedController *rearLeftMotor, SpeedController *frontRightMotor, SpeedController *rearRightMotor, float sensitivity=0.5)
	Joystick stick; // only joystick
public:
	RobotDemo(void):
		myRobot(1, 2),	// these must be initialized in the same order
		stick(1)		// as they are declared above.
		GetWatchdog().SetExpiration(0.1);
	 * Drive left & right motors for 2 seconds then stop
	void Autonomous(void)
		GetWatchdog().SetEnabled(false);
		drivetrain.Drive(0.5, 0.0); 	// drive forwards half speed
		Wait(2.0); 				//    for 2 seconds
		drivetrain.Drive(0.0, 0.0); 	// stop robot
	 * Runs the motors with arcade steering.
	void OperatorControl(void)
		GetWatchdog().SetEnabled(true);
		while (IsOperatorControl())
			GetWatchdog().Feed();
			Wait(0.005);				// wait for a motor update time
START_ROBOT_CLASS(RobotDemo);
I need help declaring the Jaguars now
Unread 14-02-2010, 15:18
buddyb's Avatar
FRC #1885 (ILITE)
Re: Motor Code Help
So now I have:
<CODE>
This *should* work. Change the values under RobotDemo(void): to change the slots.
#include "WPILib.h"
	RobotDrive robotDrive;
	Joystick stick1, stick2;
public:
	RobotDemo(void):
		robotDrive(1,				//Front Left motor port
				2,	//Back left motor port
				3,	//Front right motor port
				4),	//Back right motor port
		stick1(1),		//Joystick 1 in slot 1
		stick2(2)		//Joystick 2 in slot 2
		robotDrive.Drive(0.5, 0.0); 	// drive forwards half speed
		robotDrive.Drive(0.0, 0.0); 	// stop robot
If it works, yay! If not, play around with the ports, and make sure everything's wired correctly. If all of that is correct, I probably did something stupid. XD
Unread 14-02-2010, 18:04
odel's Avatar
Re: Motor Code Help
So this is what I have right now, we plugged the left motors into pwm 1 and the right ones into pwm 2 using pwm splitter, and still no luck
#include "WPILib.h"
public:
	RobotDemo(void):
		robotDrive(1,2),
Unread 14-02-2010, 18:22
byteit101's Avatar
Re: Motor Code Help
are the joysticks configured correctly on the driverstation?
go to setup tab, and on the right side, drag the joysticks to 1 and 2
Watchdog.Kill();
Unread 14-02-2010, 18:24
odel's Avatar
Re: Motor Code Help
Got things working now, thanks for all the help guys!
Unread 16-02-2010, 20:31
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
whatabouteve is an unknown quantity at this point
Re: Motor Code Help
might i suggest using an ancient technology of split PWM's the go from one port to 2 jaguars or victors. they are extremely helpful.
Unread 19-02-2010, 13:23
odel's Avatar
Re: Motor Code Help
We may or may not have ended up doing this...
4 motor Mecanum wheel code request inventor1254 NI LabVIEW 17 23-02-2010 08:45
ADC code effecting motor outs??? Kyveck Programming 16 28-03-2006 15:12
Adding a motor to code sirbleedsalot Programming 1 27-01-2005 23:02
hey need some help with writing a code please help me here magical hands Programming 9 01-01-2004 21:46
