Go to Post The manual can be compared to a textbook in school. If you choose not to use your textbook, you are asking to fail classes. - dez250 [more]
Unread 13-02-2010, 19:57
kavisiegel kavisiegel is offline
FRC #0061 (The Shifters)
kavisiegel is an unknown quantity at this point
6 hours, 4 mentors and 2 students couldnt figure out whats wrong with our relays
This morning, we set out to get the compressor running.
Our electronics guys wired up the compressor, and I "wired up" the program. It didn't work. So I re-did the program a few times, and then we ran some sample compressor programs... they couldn't run the compressor either. The mentor that I was working with was convinced that we have to write the compressor logic on our own, but we decided we should check to see if we have a relay problem first. At that point I found the logic in the WPI Compressor library, and we decided that it's another issue altogether.
Turns out, the compressor VI wanted the compressor to be on, but the sidecar just doesn't want to flip that relay. We tried it on slot 4 and slot 6, and we tried 3 different sidecars.
Any ideas, anybody?
www.team61.com
Unread 13-02-2010, 20:02
Re: 6 hours, 4 mentors and 2 students couldnt figure out whats wrong with our relays
Since it is unlikely that that much HW is broken, it could be a wiring problem. The sidecar needs the correct voltage to operate. I assume the PWMs and other I/O on the same digital sidecar work?
It could be a SW problem. Have you checked the diagnostics tab to see if there are errors about the relay not really opening do to a parameter or such?
Greg McKaskle
Unread 13-02-2010, 20:07
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Do you have your 12V hooked up to the sidecar? Both last year and this year I forgot to hook up the 12V, not allowing a good 5V line to be active, not allowing the compressor or switch to work.
EDIT: Oops, Greg kinda beat me to it. But yeah, check that 12V line, and ensure your 5V and 6V LEDs are on.
Jacob
Unread 13-02-2010, 20:14
The sidecar has LEDs that mirror the state of the relays. Check to see whether or not the LEDs mirror what you think the relays should be doing.
If the 5V or Battery LEDs aren't lit, its your power.
If the Relay LEDs don't light AND your PWMs aren't working, it is the ribbon cable.
If the Relay LEDs don't light AND your PWMs are working, it is likely your code (or your DSC, but not likely since you tried three).
If the Relay LEDs do light, but don't do the right thing, it is definitely your code.
If the Relay LEDs do light and do the right thing but the relay doesn't fire, it is the wiring to Spike or the Spike itself.
Unread 13-02-2010, 20:56
Greg McKaskle
Yes, the PWMs work flawlessly, and the digital input works. I'd hope a low battery wasn't to blame, we were running at about 12.3 volts.
I haven't checked the diagnostics tab specifically for relay errors, I didn't know those were displayed... I'll do that on Monday, but from what I recall, the errors there were all camera related.
Jacob
I didn't check the electronics too much, but I recall there being 3 LEDs lit.. I'll look into that a bit more on Monday.
That's actually the check we were doing. When we changed the relay values, no LEDs came on.
From the list you gave me.. well, it points right to the code. We got power. We got PWMs. We got DIO... but we used the sample programs, and that still didn't work. We tried "Compressor With Cylinder.vi" and "Solenoid With Compressor.vi" and "Relay Example.vi" and yes, we did configure them properly when we ran them.
Thanks for all the hints so far, everyone... it's really a huge help, we were pulling our hair out.
www.team61.com
Unread 13-02-2010, 21:54
Cut out the middle man and try using the relay VIs directly. I believe there is even a nice example for it - just remember to set the examples IP address*!
* Every single time I've tried to use an example, I forgot to change the IP address.
Unread 14-02-2010, 15:07
I did that too, check the post above you
And we did manage to remember to change the IP.. after a couple complete restarts.. haha
www.team61.com
Unread 15-02-2010, 11:41
OK, so we got the compressor running. We had a bad cable.
Now we got another issue, the compressor stops and starts every 10-15 pounds that it gains. Is that a normal issue? A fuse blew, and we think that's to blame.
It does this in both compressor examples as well, not just my code.
www.team61.com
Unread 15-02-2010, 13:23
Electrical Engineer
Rookie Year: 1995
If you have wired the compressor correctly, it is powered via a spike (powered by a dedicated 20A circuit breaker from the power distribution board) and the spike's fuse has been replaced by a 20A circuit breaker IAW <R60> part F.
It is possible that
1. One of the two circuit breakers as bad.
2. The pressure switch has a bad connection somewhere.
3. The current draw from the compresser is too high (bad compressor or shorted wiring).
I really do not think that could be a software issue but I'll defer that issue to others.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 15-02-2010, 15:39
Well we found the underlying issue of that, too. The watchdog timed out - it was software.
We put the light on for the first time, the bracket just got it, and we noticed that the light turned off every time the compressor turned off. Then the diagnostics tab told us the rest of the story.
So now, the new issue, WHY is our watchdog timing out?
It was originally hard wired, and we thought maybe we might have more luck wireless. Same thing. We tried it with the default robot project, no changes at all, and we tried sevral examples. It always did the same thing. We thought maybe the program was timing out because we didn't have a camera on there and the request wasn't going through, but then we attached that and nothing changed at all.
www.team61.com
Unread 15-02-2010, 15:55
nick1023 nick1023 is offline
FRC #1023
nick1023 will become famous soon enough
Make sure you have installed the latest driver station and labview updates from www.ni.com/first.
These updates have resolved some of the watchdog issues.
Here is my very broad understanding of watchdog issues at the moment. Each time the watchdog encounters an error it pauses your code running on the crio (watchdogs want to stop the machine from hurting itself if there is an error). If you call something in teleop.vi that is not opened in Begin.vi the whole control system will "pulse" in between pauses for example.
The update addressed this by making the watchdog ignore smaller errors. Ignore more small errors and you will have less watchdog errors. If you do something to cause a more "major" error you will still see watchdog timeouts.
Again, people who really know what the watchdog does are likely to wince at my explaination but it boils down to
-make sure the update is installed.
-make sure you have error free vis.
I think there was a "watchdog for beginners" explaination thread somewhere on the boards today ...
1023 Bedford Express
Unread 15-02-2010, 20:35
We had the update installed on the laptop being used, but for good measure we installed them on the driver station pc as well. Then we imaged the cRIO from the driver station and deployed the unmodified default FRC project.
Everything was as fresh as possible. And we STILL couldn't get it working.
We think it may be hardware, because with some testing, it seems we don't get watchdog errors when we unplug the digital sidecar.
I got to the school at 10 am and I left at 7 with this issue still unresolved.
www.team61.com
Unread 16-02-2010, 12:46
Do you get Watchdog errors if you leave the DSC connected, but disconnect all your DIO, Relay, & I2C connections?
Possible bare wires shorting on the Wago connector?
Unread 16-02-2010, 13:37
Yep, it was a bare sidecar connected to power, the cRIO, and the status light. And we also tried it without the status light.
We didn't try a new power cable, but I doubt that's the issue because we checked all the connections with a multimeter and it read the same as any other connection - the same exact voltage of the battery. And I don't think shorts can be that intermittent, while at semi-regular intervals... we'll try it tonight, anyways, though.
www.team61.com
Unread 16-02-2010, 14:15
Have you tried connecting one of your other DSCs to see if the problem follows the board or occurs with any DSC?
You can do replacement tests on the cRIO module and on the cRIO slot as well to eliminate each step in the electrical chain.
Figure out what's wrong with the IR board sparrowkc Electrical 5 17-02-2008 12:29
All female team- students AND mentors Marie General Forum 22 15-02-2008 13:06
What's Wrong with our Gyro??? manderson5192 Programming 4 08-02-2008 09:08
For Students only: dealing with mentors Cody Carey General Forum 1 09-02-2006 01:38
Whats wrong with this code? Morgoth Programming 4 19-01-2003 11:45
