Go to Post FRC isn't all of FIRST. - Rich Kressly [more]
Unread 14-02-2010, 16:32
hannigan hannigan is offline
FRC #2264
hannigan is an unknown quantity at this point
How can I extend my wireless reciever's power chord
I need to extend the power chord on the wireless receiver. Can I solder longer more wire on, or just connect the wire with electrical tape. Or do I have to buy wago connectors?
Unread 14-02-2010, 16:44
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
Re: How can I extend my wireless reciever's power chord
solder and tape well. heat shrink tubing over the solder connections if you can. obviously make sure there is no contact between them. another consideration is crimp on connectors. (butt connectors most likely). there is nothing saying you must use wago brand connectors. just make sure the end connected to the PDB is connected using the supplied wago connectors.
Unread 15-02-2010, 23:54
hannigan,
The proper method would be to obtain the correct connector from Radio Shack, Digikey or your local supply house and make a cable of the correct length. Other attempts are jury rig fixes at best. All of your robot commands run through the wireless adapter, if it dies so does your match.
Can wheels extend past the frame? toastnbacon Rules/Strategy 17 13-02-2010 15:48
Can the robot extend outside of the bumper zone. markulrich Rules/Strategy 15 08-01-2009 08:21
New Control System Wireless Bridge Power? Greg Marra General Forum 3 21-09-2008 17:19
To extend or not to extend the ship date! FIXIT General Forum 61 17-02-2007 14:47
We can extend beyond the playing field with our ball-knocker-offer??? Natchez Rules/Strategy 35 19-03-2004 09:35
