Go to Post Why do it the hard way if you don't have too? - ChrisH [more]
Unread 05-02-2010, 17:01
kick3nitx360 kick3nitx360 is offline
AKA: Dave.
FRC #1626 (Falcon Robotics)
kick3nitx360 is an unknown quantity at this point
Send a message via AIM to kick3nitx360
SIGNAL LIGHT WONT WORK
the signal light on our robot wont come on, and neither will the tiny one on the digital side car. Can someone help please???????
Unread 05-02-2010, 17:20
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: SIGNAL LIGHT WONT WORK
Have you confirmed your wiring matches both the Robot Power Distribution (with correct polarity) and Robot Data Connectivity diagrams, paying particular attention to the power and signal wires to the digital sidecar?
Is the digital module on the cRIO in slot 4 (with 1 being the slot nearest the lights)?
Are the lights green on on your cRIO?
Does anything else on the digital sidecar work (PWMs, sensors, whatever)?
Unread 05-02-2010, 17:34
AKA: Dave.
yes all that is done correctly. But the light that is inside the digital sidecar where you need to plug in the signal light is also not blinking
Unread 05-02-2010, 17:45
jsasaki's Avatar
jsasaki jsasaki is offline
AKA: Jun Sasaki
jsasaki has a spectacular aura aboutjsasaki has a spectacular aura aboutjsasaki has a spectacular aura about
Oh ! I had the same problem last night. Do you have two of the 40 pin sidecar modules? If so try switching the two modules and if it still doesnt work try another 40 pin cable and if it still doesn't work try re-imaging the c-Rio. If it still doesnt work i'm not sure.
Unread 05-02-2010, 21:23
Let's try a different approach. Are the three power supply LEDs lit on the sidecar? If not is there a breaker in the PD that is feeding battery to the sidecar? Have you rechecked the wiring at both the PD and the sidecar? It is a frequent mistake that wires at the PD end are not stripped the required 1/2-5/8 inches that is needed for correct insertion. Something less allows a user to insert the wire so far that the Wago will clamp down on the insulation and not the bare wire. Double check that the wire is correctly inserted at the sidecar end as well.
If the battery LED is on and the other lights are not, try removing the Robot signal light from the sidecar. If they come on with the RSL removed, you may have shorted the wiring for the RSL. If they do not come on, it is possible that the card is defective.
Unread 14-02-2010, 16:20
peter1626 peter1626 is offline
peter1626 is an unknown quantity at this point
Hi, i am another programmer from 1626.
Yes
Yes
Are the lights green on your cRIO?
Yes
Yes the entire system works except for the signal light. On the digital sidecar we have 4 victors, 1 spike, 1 sensor, and 2 servos. All work correctly.
If so try switching the two modules and if it still doesn’t work try another 40 pin cable and if it still doesn't work try re-imaging the c-Rio.
We have tried 4 modules, 2 40 pin cables, 2 digital sidecars, and 2 cRIOs. We also have reimaged the cRIO numerous times.
Yes
Yes the sidecar is in the 30 amp spot with a breaker
Yes we have rewired the entire system 4 times
The 3 power/ battery lights are on the digital sidecar. The Signal light still doesn’t blink and when we remove the signal light the small green led does not blink.
Please HELP! We don’t know what else to do!
Thanks for your help!
2010 SBPLI Long Island-Regional-Imagery Award in honor of Jack Kamen
2011 New York City Regional-Industrial Design sponsored by General Motors
2011 SBPLI Long Island Regional-Regional Winner
Unread 14-02-2010, 16:48
samir13k samir13k is offline
AKA: Samir Shaikh
FRC #4329
samir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant futuresamir13k has a brilliant future
Send a message via AIM to samir13k Send a message via MSN to samir13k
attempt to download the original code to the cRio once again. it should not make a difference as it should not be changable in the code, but in FIRST, sometimes you just have to try anything.
Unread 14-02-2010, 16:53
Just tried this, it did not work!
What is the current image name that should be on the cRIO?
Unread 14-02-2010, 17:29
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Try picking up your robot, flipping it over, and banging on it, then pick it up and shake it. This will remove all metal shavings, which can short parts of the DSC. We have had to do this twice already on our robot, we know it happens when the +5 light on the DSC goes off and nothing works, but the DSC still has power lights on.
Kettering Motorsports
Unread 14-02-2010, 18:52
Originally Posted by peter1626 View Post
Yes
Can you take a picture and post it? The only thing I can think of that matches your symptoms is having the module in Slot 6 instead of Slot 4.
Unread 14-02-2010, 20:30
Pausert Pausert is offline
FRC #1727 (REX)
Pausert is an unknown quantity at this point
Check to make sure have the Digital Sidecar power wired + to + and - to -. The digital sidecar will function (partially) even if its supply power is backwards, but the signal light will not function in this circumstance.
Unread 14-02-2010, 20:47
Peter,
You have tried everything I would have gone through. That really leaves only the side car as being defective. If the PWM signals that pass through are functioning normally and are disabled when the robot is disabled then it can only be the side car.
A software expert can answer this better than I but the default code is written such that the RSL functions when the robot is disabled and flashes one of a series of codes that indicate certain conditions on the robot. When enabled, the RSL light should come on solid.
"There are four states of this status LED, listed here in order of priority. If multiple occur, the highest one listed is what is displayed.
1. Fast Blink (200ms on / 200ms off) - System error: No driver's station communication, bad cRIO Image, bad team ID, extensive communication errors.
2. Steady on - Everything ok
3. Fast-Slow Blink (200ms on / 900ms off) - System disabled either by system watchdog, user watchdog, or Driver's Station set to disabled and low battery (<12 Volts)
4. Slow Blink (900ms on / 900ms off) - System disabled"
Unread 14-02-2010, 23:41
AKA: Samir Shaikh
FRC #4329
image v19 would most likely be on your cRio. If you installed the latest update (out since fridayish?) you should currently be at v20 which you will need to do. download and install both the Labview and DS updates. I dont believe that this will fix this problem if you are already running v19, but its a mandatory update non-the-less
Unread 15-02-2010, 11:42
AKA: Dave.
Here are the pictures you asked for.
Unread 15-02-2010, 11:51
AKA: Dave.
yes samir, we are using v19 when we image the cRIO.
Dashboard wont work... nadavsen2 C/C++ 2 22-09-2012 15:43
Robot Signal Light smcmahon Electrical 20 08-03-2009 18:11
FRC Signal Light railerobotics Programming 1 07-02-2009 17:01
Signal Light DustinB_3 Electrical 10 21-02-2007 13:10
Festo valve.... why wont it work? CHSguard72 Pneumatics 3 08-02-2003 19:07
