Go to Post Brace yourselves, reality check incoming. - EmileH [more]
Unread 02-08-2010, 04:06 AM
Deep-Blue Deep-Blue is offline
FRC #1937
Deep-Blue is an unknown quantity at this point
Exclamation "No Robot Code" problem
Hi, I am programming on C++ in WindRiver. Until a week ago everything worked fine and my code worked well, about a week ago i started getting the "No Robot Code" message on the Driver Station. I then started trying to find the problem, after about an hour it suddenly started working again. The strange thing is that i didn't change a thing... it was the exact code that didnt work before. The problem is that now I updated the workbench to 4.1 and since then keep getting the "No Robot Code" problem. I even tried downloading the original SimpleRobot template untouched but still, "No Robot Code". There are no errors undeploying or downloading code, and yet the code doesn't run.
I will be thankful for every advice.
Asaf.
Unread 02-09-2010, 05:09 PM
whatabouteve whatabouteve is offline
AKA: Dean Keithly
FRC #0245 (Adambots)
whatabouteve is an unknown quantity at this point
Re: "No Robot Code" problem
This might be a problem with the system resetting itself. After updatung did you change the prefrences to download the correct ".out" file?
Look at another post by me in "code doesn't load" solution.
its a video link that should be used with the FRCprogramming guide if what I said above is your problem.(I think it is because you said you switched code)
Unread 02-09-2010, 08:29 PM
gjordan gjordan is offline
AKA: Greg Jordan
FRC #3126 (FlashPoint)
gjordan is an unknown quantity at this point
A number of people had an issue with 4.1. When using the DriverStationLCD class, the code would not load and an error about a symbol would be displayed on the serial console.
If the above is the case, then 4.2 fixes the DriverStationLCD issues, but are now having a similar issue if using the AxisCamera class. When removing this class now, our code works.
If you are using net console or can connect a serial cable to the cRio and connect via a terminal emulator, there is loads of useful information that will be displayed.
_Greg
Unread 02-14-2010, 05:13 PM
FRC #1937
I changed to the right .out file each time... it didnt help.
after re-imaging the crio my code came back to life again, and a while after updating to 4.2 it stopped working again... same error.
i tried re-imaging the crio again, but this time it didnt work... what do i do?
Unread 02-14-2010, 05:57 PM
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
http://first.wpi.edu/FRC/frccupdates.html
Scroll down to the NetConsole instructions. Install it and post what errors show up on the console
G-FORCE's robot, named "philbot" a.k.a "armagedon in a polycarbonate box" Bryan_2818 Robot Showcase 0 04-12-2009 08:54 PM
Modified default code gives "code violation" scottmso Programming 8 02-10-2006 11:17 PM
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 01-10-2006 06:07 PM
IFI Loader problem - "Invalid HEX file" wun Programming 9 09-22-2004 12:35 PM
Potential Problem with "fighting over the goal" Kyle Fenton General Forum 4 02-17-2002 10:21 AM
