Go to Post By far, the worst thing about it was the severe lack of cowbell. There was no cowbell what so ever. Had there been cowbell that would have completely changed everything for me. - Wildcat [more]
Unread 10-02-2010, 15:41
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Re: Joystick Button Flip Flop
Just in case someone needs a Flip-Flop latch for a boolean.
Omar
Unread 10-02-2010, 17:01
D Peterschick D Peterschick is offline
Aggies Robot Team Coach
FRC #2923 (Aggies)
D Peterschick is an unknown quantity at this point
Re: Joystick Button One-Shot (a.k.a. Rising Edge) Detection
On the response to keep the limit switch with the motor going value from going less than zero? How do we do that?
Software kids are stumped!
Unread 10-02-2010, 20:19
Using the "In Range and Coerce" function makes it easy. The attached image shows the True case, where the value is to be limited. The False case simply wires the value straight through without modification.
Name:	limit switch.jpg
Unread 13-02-2010, 15:02
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
Really frustrated!!! We are close to throwing in the towel. Alan you keep saying this is easy, but we have spent countless hours over the past two years trying to get a switch to stop a motor without any success...it may be easy for all of you in this forum but I guarantee that we are not the only ones having this issue. We have been relying on the graciousness of Chief Delphi and LVMastery to get our robot programmed.
Can anyone write and attach a sample program with ALL of the elements included.
Here is what we need:
If button 1 is pressed a motor will spin until the limit switch is closed... AND it will not keep spinning even if the button 1 is pressed...AND it will spin in the opposite direction when button 2 is pressed even if the limit switch is closed.
We're not trying to cop-out we just need to see and example to understand the thinking behind what we are trying to do.
Unread 13-02-2010, 15:12
Using a speed controller or a Spike?
Is the motor driven full speed in forward and reverse, e.g., on a Spike?
Does button 2 interrupt what button 1 started, or is the button 1 action stopped solely by the limit switch?
How do you want to stop after button 2 is pressed? Is there a limit switch at the other end too?
Unread 13-02-2010, 20:08
FRC #2147
We are using a speed controller to power a Denso window motor BUT we could use a Spike if it would be easier.
Just to clarify-
We want a ramp to move UP when button 1 is pressed AND only when button 1is pressed. We want the ramp to go DOWN when button 2 is pressed AND only when button two is pressed.
Our issue is we need the ramp to stop when the ramp is all the way down, hence the need for a switch. We don't want to rely on the driver seeing that the ramp is down and letting go of the button in time. The plastic hex output shaft on the Denso window motor is awfully susceptible to shear.
Thanks for the help.
Unread 14-02-2010, 12:00
Controlling a motor with a pair of buttons is not difficult. Use the state of the first button to select between the True and False of a case block, wiring a constant zero out of the False case and wiring the desired "UP" motor speed out of the True case. Run that output through another case block controlled by the second button, wiring the value straight through without modification in the False case and wiring the desired "DOWN" motor speed out of the True case. Run that output through the In Range and Coerce select block controlled by the limit switch; I showed an example of that a few posts ago.
Unread 14-02-2010, 16:55
FRC #2147
Alan- Is this what you are describing?
Unread 14-02-2010, 18:28
Not quite. I suggest that the motor should be set only once at the end of the process, with just the numeric values that will be set going through the case blocks.
It looks like your ramp runs upward with -1 and downward with +1, so the "down" limit should prevent the value from going positive. Using -1 and 0 as the range limits will let it run upward but not downward when the limit input is active.
(The three "False" cases at the top are just there to show what's going on in the bottom case blocks.)
Unread 14-02-2010, 20:50
FRC #2147
Thanks for the life-ring. I think I understand how this works now.
Can I ask one more question? Can you explain the logic of the In Range and Coerce for this instance. I have read the context help but don't understand how it works in this instance.
Thanks again!
Unread 14-02-2010, 22:26
In Range and Coerce takes a lower limit, an upper limit, and an input value. It then does two things.
1: It provides an "In Range" boolean output that is True when the value is between the limits, and False when the value is outside the limits. This feature is not used in the code I showed.
2: It provides a "Coerce"d output value that matches the input value when it is inside the limits, but does not exceed the limits in either direction when the input is outside the range. This is how the motor is kept from driving in a particular direction, by making sure the value never goes above 0.
Ellipse Finding/Edge Detection Example Code? brianc217 NI LabVIEW 3 20-01-2010 08:57
Full solenoid controll off of one joystick button? m3rc1l3ss NI LabVIEW 2 11-02-2009 02:06
joystick button furiousgeorge Programming 5 07-02-2009 15:57
Ganged Interrupt Edge Detection cprogrammer Programming 8 01-02-2008 10:52
More than one joystick from one port Jmoo Programming 3 26-06-2003 18:01
