Go to Post FIRST is like a big roller coaster, that can only be experianced if one takes a ride which can become a liftime experiance. - activemx [more]
Unread 14-02-2010, 18:29
Free Willy's Avatar
Free Willy Free Willy is offline
Free Willy is an unknown quantity at this point
Pressure Regulator Placement
We are planning on using three pressure regulators, one at 120psi for the storage tanks and two at 60psi after the solenoid right before the piston. Would this be legal or does the air going through the solenoid count as "working"
Unread 14-02-2010, 18:39
Re: Pressure Regulator Placement
I'm going to say that the inspectors will want you to move that one to before the solenoid.
<R76> “Working” air pressure on the ROBOT must be no greater than 60psi. All working air must be provided through one primary Norgren adjustable pressure regulator.
A. All “working” pneumatic components (e.g. valves, cylinders, rotary actuators, etc.) must be downstream from this regulator.
B. Only the compressor, relief valve, pressure switch, pressure vent plug valve, pressure gauge, storage tanks, tubing, and connecting fittings may be in the high-pressure pneumatic circuit upstream from the regulator.
Let's see here: Solenoids could be counted as valves. Solenoids are not explicitly allowed upstream of the primary regulator and are therefore illegal to have upstream of said regulator.
You'll definitely have to move that regulator that supplies the working stuff. And don't forget, you'll need the gauges to verify the setup.
Electrical Engineer
Rookie Year: 1995
<R76>, part B, does not allow for solenoids on the high pressure side of the main pressure regulator.
Mike Betts
As easy as 355/113...
Unread 14-02-2010, 19:04
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
There is no 120psi regulator just a pressure relief valve.
The important rule is
You can have up to 4 tanks before this regulator to store air at 120psi. That the pressure vent and the pressure switch are all you can have in front off the 60psi regulator. All other components are on the low pressure side of that regulator.
adjustable pressure regulator windell747 Technical Discussion 25 31-01-2010 11:20
Pressure regulator Perci321 Pneumatics 13 24-01-2009 18:48
Does the Norgren Pressure Regulator show working pressure or stored pressure? Madison Pneumatics 7 14-02-2008 17:40
Nason Pressure Regulator Calvin_1631 Pneumatics 9 09-02-2006 00:40
pressure regulator blindguyinanorg Pneumatics 12 20-02-2004 08:54
