Go to Post We discovered this problem on the ship day (sure, when else?) - Manoel [more]
Unread 09-02-2010, 10:05
Re: problems with using switches for autonomous
Are you using compatibility i/o or extended i/o?
Alan, you forgot the code fragment.
Unread 09-02-2010, 16:56
I thought it was there when I wrote the post this morning. Here it is (again).
Name:	Autonomous Select.jpg
Unread 09-02-2010, 23:12
ssica_jj ssica_jj is offline
FRC #0368 (TKM)
ssica_jj is an unknown quantity at this point
Smile Re: problems with using switches for autonomous
We tried what you suggested. It works! Thank you for your help! We really appreciate it.
Unread 14-02-2010, 17:07
fkm300 fkm300 is offline
fkm300 is an unknown quantity at this point
We are having similar problems with getting the PSoC inputs to be seen on the Dashboard. We have placed Get Dig In on the Dashboard.vi but don't see any states change. The states do change on the Driver Station. Does anyone have any suggestions on what we should do?
Thanks!
Komal
Unread 14-02-2010, 18:41
The Get Digital In vi only works on the robot. If you want to show its output on the Dashboard, the robot program will have to send it in the Dashboard data and the Dashboard program will have to retrieve it from there.
Unread 12-03-2010, 11:31
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Originally Posted by ssica_jj View Post
We ran the RobotMain.vi in the project containing the code. We connect the laptop to the router which is connected to the driver station.
Attached is a screen shot of our code.
we have our auton. working in the same way you guys do except on ours we have the boolean output of the "get Dig. in" block going to a block that gets the ID of the switch and goes directly into a case structure. inside the case we have different "pages" that have different auton. programs. the DIG. In is what controls the program.
-Time is the best teacher...unfortunately it kills all of its students. --Robin Williams
Unread 13-03-2010, 21:39
garrettg garrettg is offline
FRC #1528 (Monroe Trojan Robotics (formerly iPirates))
garrettg is an unknown quantity at this point
What our team did was use 2 PWMs attached to a 3-way switch mounted on the robot, and made 2 case structures, one inside the other for autonomous. We wired digital IOs into the case strucures, and that's how we get our autonomous selection.
Programming toggle switches to DS for different autonomous routines? grosh NI LabVIEW 9 30-03-2009 20:42
Problems with using 330's goal tracking code windell747 NI LabVIEW 11 16-02-2009 13:02
Using Limit Switches with the Arm iwin2000 Programming 3 18-02-2008 03:52
Problems with transmission using Inventor 8 Drew Hopman Inventor 4 10-01-2005 19:07
laser radar with BS2p using RS232 problems... chei_UCF19 Programming 6 26-02-2004 15:21
