#7
Re: Encoder Trouble
I never did get one of our encoders working. I had several of our mentors check the wiring and setup and no one could explain it.
Current is passing through the wires, says the voltmeter. It has power, says the red light on the encoder. The disk and base are an appropriate distance away from each other, because the cap is on (though one of the disks was noticeably scratched the other was still unsuccessful). I've accepted that I can't expect to have them working by the end of build season. Is my next step to see if a brand new set have the same issues? |
| Lab View Update 3.0 encoder trouble | Funnyman2003 | Programming | 2 | 03-02-2009 08:52 |
| Screwing Encoder into Encoder Mount? | Adrien | Electrical | 3 | 25-01-2009 18:14 |
| KOP Gear Tooth Encoder Trouble | Sykan | Programming | 11 | 16-02-2008 20:53 |
| Inventor software trouble/ FIRST Base trouble | nasa-senpai | General Forum | 2 | 24-01-2007 09:15 |
| encoder.c | Gary Bonner | Programming | 2 | 14-01-2005 13:41 |
