Re: Jaguar Lights
All four having shavings in them is kinda unlikely. Check the PWM's, I recommend hot-gluing them into the jags once you get everything fixed up. Also check the little black jumpers on the Sidecar, they could have been jarred loose at some point. good luck! |
Re: Jaguar Lights
Looking at the Jaguar manual "Getting Started", it appears you are correct that the Jaguars will flash fast red/green when the motor is not going full speed and only solid when going full power. So that explains that part, but it doesn't explain why our robot would cease working when we're driving it. Naturally not knowing anything about the Jaguars, flashing lights seemed bad. Hm.. Thanks -Tanner |
Re: Jaguar Lights
Does your digital sidecar have power? If you remove the 37 pin cable, do the 3 power LEDs remain lit? Is the 37 pin cable firmly mounted?
Re: Jaguar Lights
I would take a closer look at your color codes for the LEDs. On a Jaguar quick flashing green means that it is receiving a forward signal that is less than 100%. Quick flashing red means that the Jaguar is receiving a backwards signal that is less than 100%. Check on the speed of the flashes.
Re: Jaguar Lights
-Tanner |
Re: Jaguar Lights
Goodness, many things.
For one, does everything seem to work OK when the wheels are in the air? Run the drivetrain like that for a while, to break in the gearboxes (and, to a lesser degree, motors). 30 to 60 minutes of unloaded movement will help. Next, what's the robot configuration? If you have 4 wheels, one in each corner of the robot, and are trying to turn with high-traction wheels - you may be popping breakers. That's about the worst-case for turning. Does it drive well when you go in only straight lines (no turns)? The gear ratio also affects this - very high ratios (slow speeds) allow better turning. Low ratios don't leave enough torque to turn well, even with 6 or 8 wheel drive. Lastly, check the system voltage while the problem is present. Voltages dropping to less than 10.5 volts or so may indicate a wiring or battery charge issue. Run all the motors (off the ground) and, using a voltmeter. find where the voltage drops are. From the - battery terminal (the metal of the battery itself, NOT what you have connected to the terminal!) to the PDB it should be very small; similarly, from the + terminal to the PDB should be almost the same (we expect a larger voltage because of the main circuit breaker). Then from the PDB input bolts to the input screws of the Jaguars (one at a time). If you find a high voltage (as compared to the rest of them, assuming at least one is "good") you need to correct it. Voltages around 0.1 to 0.5 are in the range I'd expect. So, tell us more... |
#7
Re: Jaguar Lights
Tanner,
The condition you describe is a classic over current condition particularly in turns. However, the LED colors you report are not consistent with that condition. I would expect a steady ON RED indicator if the Jaguar was in a fault condition. According to the Jaguar manual, a flashing yellow indicates a loss of CAN or servo control. That points back to the sidecar, it's power connector and wiring, or the cable between the sidecar and Crio. Since you did not indicate you are using CAN, I am guessing the other flashing yellow code do not apply. If you are using CAN, the flashing yellow can indicate CAN ID problems. |
| Jaguar | Brandon_L | NI LabVIEW | 1 | 21-01-2010 19:49 |
| Yellow Flashing Jaguar/Victor Lights | AlbertW90 | Electrical | 10 | 16-02-2009 11:06 |
| Jaguar and Victor Flashing lights? | programmr | FRC Control System | 24 | 17-12-2008 15:44 |
| No lights on camera | Bob22341 | Programming | 4 | 08-02-2006 13:27 |
| Lights? | Total Meltdown | Programming | 2 | 17-01-2006 00:35 |
