Go to Post Actually, I think the standard Klingon warning label ought to be sufficient: 'yIQIpQo' (don't be stupid) - Alan Anderson [more]
Unread 10-02-2010, 19:31
matthewfl matthewfl is offline
FRC #0687 (Nerd Herd)
matthewfl is an unknown quantity at this point
Axis m1011 camera
Can we use a Axis M1011 camera, as our camera that came with the kit of parts has stop working.
Unread 12-02-2010, 19:11
Re: Axis m1011 camera
Yes you can. That is the recommended replacement.
If the camera stopped working but wasn't zapped due a ground fault or smashed by the HULK, you may be able to reset it using the button on the back. You may also want to check the power before ordering another.
Greg McKaskle
Unread 13-02-2010, 01:18
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
You say the "recommended" replacement. Do you know of any others that work with the code? I would assume most of the similar Axis cameras would work, but would something like a D-Link or Airlink camera work? I've seen that there is an Axis-specific (well, named as such) initializer in the LabView code, is that only for Axis, or just to be obvious to the programmer?
Unread 13-02-2010, 05:00
Most of the IP style security cameras can be made to work as long as they produce either jpeg or mjpeg formatted images.
The Axis cameras follow a pretty consistent API, and should be pretty interchangeable. I haven't seen anything that makes the other Axis cameras appealing within the price range for FIRST. Features such as interchangeable lens, a programmatic way to request a portion of an image, would be nice, but don't seem to be available.
If testing a camera from another manufacturer, you'll need to modify the http requests to match what the camera expects. This is certainly doable, probably in one day. Be sure to evaluate the camera lag. Especially on the low end, the cameras may not have HW accelerated jpeg encoding, and that can introduce quite a bit of additional lag meaning that the robot is measuring and responding to events in the past, and once the lag gets to be more than a few hundred ms, it makes it very difficult to use.
Greg McKaskle
Unread 14-02-2010, 19:22
Steve Warner Steve Warner is offline
Controls / Programming
FRC #0234 (Cyber Blue)
Steve Warner is an unknown quantity at this point
Today we started using the M1011 with C++ and not having much luck. We set up the camera just like we did the 206 but it's not working. Has anybody used the M1011 with C++ and gotten it working?
Unread 15-02-2010, 23:37
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
We are thinking about getting an Axis m1011 camera. Does anyone know whether it will fit in the pan and tilt assembly we got in the KOP?
Please don't call me Mr. Ed, I am not a talking horse.
Unread 20-02-2010, 00:39
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Steve,
The M1011 seems to working fine for us under C++. This thread also discussed the topic.
AXIS M1011 camera - Is anyone using it? adamdb Kit & Additional Hardware 0 05-02-2010 11:00
Java/Netbeans Camera Code for Classmate PC and Axis Camera joshholat Programming 1 23-01-2010 14:59
Axis Camera ehochstein Programming 2 21-02-2009 00:16
Model of Axis Camera Bochek CAD 2 18-01-2009 17:50
AXIS Camera nickmagus Programming 1 03-01-2009 20:06
