Go to Post If you want to make change, you have to know what you're trying to change. - [more]
Unread 14-02-2010, 23:49
z2daj z2daj is offline
FRC #2836 (Team Beta)
z2daj is an unknown quantity at this point
Send a message via AIM to z2daj
Limit Switch Draws Tears
Imagine yourself: 11 hours, 5 programmers, no mentors, 1 fiesty limit switch. The result? 5 programmers suffering a severe mental breakdown.
We are attempting to program a very simple limit switch that will disable a motor when the limit switch circuit is closed. We have wired the two limit switch wires into to the ground and signal connections on input four of the digital sidecar. We are programming in C++ and whenever we attempt to get a signal back from the input it always shows up as equaling one, no matter what we do. Please help us, it seemed so simple when we started 11 HOURS AGO!
There is nothing to fear, but fear itself
limit switch solomason519 Programming 9 09-02-2010 08:50
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
limit switch wedellm Electrical 4 16-02-2007 13:01
Limit Switch Basics JWSnedden Programming 6 30-11-2006 19:48
