Go to Post When I'm asked the question, "What is the most important computer language to learn to prepare me for a programming career?"; my answer is, "Your second one." - Greg McKaskle [more]
Unread 14-02-2010, 23:49
z2daj z2daj is offline
FRC #2836 (Team Beta)
z2daj is an unknown quantity at this point
Send a message via AIM to z2daj
Limit Switch Draws Tears
Imagine yourself: 11 hours, 5 programmers, no mentors, 1 fiesty limit switch. The result? 5 programmers suffering a severe mental breakdown.
We are attempting to program a very simple limit switch that will disable a motor when the limit switch circuit is closed. We have wired the two limit switch wires into to the ground and signal connections on input four of the digital sidecar. We are programming in C++ and whenever we attempt to get a signal back from the input it always shows up as equaling one, no matter what we do. Please help us, it seemed so simple when we started 11 HOURS AGO!
There is nothing to fear, but fear itself
Unread 14-02-2010, 23:56
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Limit Switch Draws Tears
what are you using to discover the value? The Dashboard? If so the default dashboard code returns hard-coded values that do not reflect the status of the system
Make sure the digital module is on slot 4. Also make sure power is properly wired to the sidecar. Try last year's sidecar if you have to. Also try a different limit switch.
If you are using the CAN bus for motor control, you could just directly wire the limit switch to the Jaguar and forget about this entire mess
Unread 15-02-2010, 00:08
Have you verified that the switch works? How?
What are you using as a limit switch? The microswitches I'm familiar with have three connections.
Unread 15-02-2010, 00:14
As far as we can tell everything is as you say, we have the module in slot 4 and are attemting to get the state of the input directly from the module itself not the dashboard. We simply created an object called Dig4 and set it equal to DigitalInput(1), here's the code.
#include "WPILib.h"
#include "Vision/AxisCamera.h"
#include "Vision/HSLImage.h"
#include "PIDController.h"
#include "Gyro.h"
#include "Target.h"
#include "DashboardDataSender.h"
#include "Jaguar.h"
#include "Compressor.h"
#include "Solenoid.h"
#include "Victor.h"
class DefaultRobot : public SimpleRobot
	//RobotDrive *myRobot;			// robot drive system
	Joystick *rightstick;			// joystick 2
	Joystick *leftstick;			// joystick 1
	Gyro *gyro;						// gyro initialization
	DashboardDataSender *dds;		// Driver station data sender
	DriverStation *ds;				// driver station object
	Victor *jag1;// single jaguar motor control
	Victor *jag2;
	Victor *jag3;
	Victor *jag4;
	Compressor *compressor; 		// new compressor object
	Solenoid *solleft;				// solenoid on left
	Solenoid *solright;				// solenoid on right
	DigitalInput *Dig1;
	enum Resolution_t
			kResolution_320x240
	/*enum							// Driver Station jumpers to control program operation
	{ ARCADE_MODE = 1,				// Tank/Arcade jumper is on DS Input 1 (Jumper present is arcade)
	  ENABLE_AUTONOMOUS = 2,		// Autonomous/Teleop jumper is on DS Input 2 (Jumper present is autonomous)
	} jumpers;	*/
public:
		DefaultRobot(void)
		GetWatchdog().SetEnabled(false);
		ds = DriverStation::GetInstance();
		//myRobot = new RobotDrive(1, 3, 2, 4);	// create robot drive base
		leftstick = new Joystick(1);
		rightstick = new Joystick(2);			// create the joysticks
		dds = new DashboardDataSender();		// dashboard data sending
		compressor = new Compressor(10, 8);  //compressor on ports 10 and 8
		solleft = new Solenoid(1);			 //solenoid on ports 1 and 2(below)
		solright = new Solenoid(2);
		jag1= new Victor(1);
		jag2= new Victor(2);
		jag3= new Victor(3);
		jag4= new Victor(4);
		Dig1 = new DigitalInput(1, 1);
		//Update the motors at least every 100ms.
	 * Drive left & right motors for 2 seconds, enabled by a jumper (jumper
	 * must be in for autonomous to operate).
	void Autonomous(void)
	void OperatorControl(void)
		AxisCamera &camera = AxisCamera::GetInstance();
		camera.WriteResolution(AxisCameraParams::kResolution_320x240);
		camera.WriteBrightness(200);
		while (IsOperatorControl())
		{	GetWatchdog().Feed();
			if (Dig1->Get() == 0)
				jag1->Set(0.0);
				jag2->Set(0.0);
				jag3->Set(0.0);
				jag4->Set(0.0);
			else if(Dig1->Get() == 1)
				jag1->Set(-leftstick->GetY());
				jag2->Set(rightstick->GetY());
				jag3->Set(-leftstick->GetY());
				jag4->Set(rightstick->GetY());
			else
				jag1->Set(-1.0);
				jag2->Set(1.0);
			compressor->Start();
			if (leftstick->GetRawButton(2))
				//jag->Set(1.0);
				solleft->Set(1);
				solright->Set(0);
			else
				//jag->Set(0.0);
				solleft->Set(0);
				solright->Set(1);
			//myRobot->TankDrive(rightstick, leftstick);
			compressor->GetPressureSwitchValue();
};START_ROBOT_CLASS(DefaultRobot);
We have also used our multimeter to check the limit switch and the digital side car works for everything else we have used (motors, compressor, gyro and so on). We also found out earlier that this year it is illegal to connect the limit switch directly to the jaguar in accordance to R<54>.
Soo, we are still stuck.
Unread 15-02-2010, 00:29
Which rule was that? <R54> is the no modifying motors rule.
<R60-L> reads:
L. If CAN-bus functionality is used, limit switch jumpers may be removed from a Jaguar speed controller and a custom limit switch circuit may be substituted (so that the cRIO-FRC may read the status of the limit switches).
Also see:
<R68> All outputs from sensors, custom circuits and additional electronics shall connect to only
G. the CAN-bus if and only if all Jaguar speed controllers on the CAN-bus are wired in full compliance with Rule <R63> and Rule <R64>, or
H. the sensor inputs on the Jaguar speed controller.
Unread 15-02-2010, 00:34
John G John G is offline
FRC #0399 (Eagle Robotics)
John G is on a distinguished road
This is going to sound very strange, but today (we haven't ever come in on sunday before) my team was supposed to spend 4 hours in the shop to clean up the wires on our bot for a revealing day/ showcase tommorow. After putting everything back together, our robot still didn't run. 5 hours later we realized that a limit switch was creating a short. It took us about a total of 13 hours to get it going. I feel your immense pain.
AKA: Dr. Brooks
no team (WRRF)
<<< Dig1 = new DigitalInput(1, 1); >>>
Your digital sidecar is in slot 4, so the line above should be
Dig1 = new DigitalInput(4,1);
if my memory serves me correctly, assuming that
you are using digital input 1 as the code implies.
Unread 15-02-2010, 00:35
MattD's Avatar
MattD MattD is offline
AKA: Matthew Douglas
FRC #0228 (GUS Robotics)
MattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to beholdMattD is a splendid one to behold
Send a message via AIM to MattD
In your constructor, I see this line that stands out:
The DigitalInput constructor you're using looks like this:
DigitalInput::DigitalInput(UINT32 slot, UINT32 channel)
By constructing with DigitalInput(1, 1), it will try to look for a digital input on module 1. This won't work, since that's the analog module.
If you change it to look like this it should read Digital Input #1 from the default digital module (module #4).
Dig1 = new DigitalInput(1);
GUS Robotics Team 228
2010 WPI Engineering Inspiration Award
2010 WPI Regional Champions (Thanks 230 & 20!)
2010 CT VEX Champions
2010 CT VEX Innovate Award
2009 QCC VEX Champions
2009 CT Motorola Quality Award
2007 CT J&J Sportsmanship Award
2006 CT Best Website Award
Unread 15-02-2010, 00:37
Electrical Engineer
Rookie Year: 1995
... Dig1 = new DigitalInput(1, 1);`...
In your original post you state that the swich is wired into input 4 on the digital sidecar. And, as Alan pointed out, the cRIO digital module should be plugged into slot 4.
Therefore, I would guess that the statement above should be
Dig1 = new DigitalInput(4, 4);
Or am I missing something?
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 15-02-2010, 00:51
...We simply created an object called Dig4 and set it equal to DigitalInput(1), here's the code.
[edit]Yeah, lots of people caught this one.[/edit]
Last edited by Alan Anderson : 15-02-2010 at 00:52. Reason: took me too long to look up the documentation
Unread 15-02-2010, 01:28
We have tried all of the possible solutions however they have all failed terrifically.
Unread 15-02-2010, 01:57
Electrical Engineer
Rookie Year: 1995
OK. That statement really scares me...
Now, don't get me wrong. Your code has more than one problem (like 3 conditions for a Boolean condition) but, for anyone to help, you need to clearly define what is wired and what you want to do, in plain language please...
Mike
Mike Betts
Unread 15-02-2010, 02:28
where exactly would these 3 conditions for a boolean variable be?
Unread 15-02-2010, 02:53
AKA: Dr. Brooks
no team (WRRF)
The digital input is one, or zero.
Don't count on the code handled by the final else
statement to ever get executed.
jag1->Set(0.0);
jag2->Set(0.0);
jag3->Set(0.0);
jag4->Set(0.0);
else
jag1->Set(-1.0);
jag2->Set(1.0);
Unread 15-02-2010, 06:10
Electrical Engineer
Rookie Year: 1995
Ahhh... While I sleep, my minions carry on!
Thanks Doc.
A switch is either ON or OFF...
Mike Betts
limit switch solomason519 Programming 9 09-02-2010 08:50
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
limit switch wedellm Electrical 4 16-02-2007 13:01
Limit Switch Basics JWSnedden Programming 6 30-11-2006 19:48
