Go to Post I understand that I'm in the minority when it comes to these things, so when the coverage switches to one these stories I exercise my right to change the channel. - Karthik [more]
Unread 15-02-2010, 00:29
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Dashboard Datatype?
Hi everyone,
I searched, so please don't flame
Anyway, so I've decided to finally make a custom dashboard. I've spent the night figuring out how these clusters are packed (we're using Java this year). I understand the structure for the sample code, and I can find the cluster in the block diagram from the sample LabVIEW dashboard program (on the left, Low Level robot I/O values). I can see how those structures match up to the provided dashboard Java code cluster structures.
Wonderful.
So, how do I create a custom structure in LabVIEW? I'm not even entirely sure what's going on here (I've never used LabVIEW for anything more than real-time signal capture not related to FIRST.) This "box" (I'll call it that until someone can describe to me in more detail what it does) has all of these clusters inside. Where is this "box" getting its data from? How do I make a "box" with my own structure? Is there any way I can not use a mouse to do this? (that one was rhetorical).
Anyway, if anyone can help me understand what's going on here, I'd greatly appreciate it.
Thanks!
Jacob
Unread 15-02-2010, 00:39
Re: Dashboard Datatype?
If I understand what you're referring to, that "box" is a cluster constant. You can place one on the block diagram, and then place other constants (string, numeric, boolean, etc.) inside it in the desired order to create a cluster of your own design.
Unread 15-02-2010, 00:41
AKA: Jacob Komar
Thanks for the fast response, Alan.
So I can simply place my own in place of the one thats there, and it will work? How does LabVIEW know where to get the data to fill those constants? Do I need to call the cluster constant something specific? Where can I find these constant pieces?
EDIT: OH!!! I think I get it. That block on the side is the 'Type' input to the String deflattener. HAH! *excited*
Thanks again,
Jacob
Unread 15-02-2010, 00:54
AKA: Jacob Komar
One more question, the types of boxes that the default dashboard program uses (Slot 1, Slot 4, Slot 8).. How can I create those? I can only seem to create simple LEDs etc, without those fancy segmented boxes?
Unread 15-02-2010, 01:05
I think what you're calling "fancy segmented controls" are just colored rounded box Decorations, Grouped with regular controls on top of them. While you're editing the default dashboard front panel, select one of them and use the rightmost icon on the tool bar to Ungroup them. There's a Tools Palette under the View menu that you can use to set decorations' colors.
Unread 15-02-2010, 01:51
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
By the way, creating a custom control typedef may make things slightly easier when you update the custom datatype on the dashboard.
While you won't be able to use it on your Robot project (Java vs LabVIEW), you will be able to use it as a block diagram constant and the front panel indicator. If it's a strict typedef, you will be able to edit the user data datatype AND how it is displayed by just modifying this file.
(you will still have to open it up and build it as an exe for seamless integration with the driver station)
Here's an example typedef:
(apologies about the page stretching)
-- Marshal Horn
Dashboard Dr Nick Programming 3 03-02-2008 11:33
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
2004 Dashboard Protocal vs 2005 Dashboard Protocal Kyle T Programming 4 14-03-2005 22:19
dashboard archiver 2000 1 23-06-2002 23:06
Dashboard in VB archiver 2000 2 23-06-2002 22:49
