Go to Post The competition is about MUCH more than just the robot. If kids are glued to the robot all of the time, then they miss the rest of it... the other fun stuff, what makes FIRST, FIRST. - Kims Robot [more]
Unread 15-02-2010, 02:31
ecnahc515 ecnahc515 is offline
FRC #3192
ecnahc515 is an unknown quantity at this point
Re: Need help w/ moving Camera Servo motors.
Originally Posted by umangv620 View Post
Thats what we had. We were getting errors, so we deleted that part and opened the joysticks and drive in now robot main(not teleop) and closed it in robot main as well. When we do this, our joysticks function correctly.
When we open the joysticks and the drive in begin.vi and reference them, the joysticks act funny and so does drive. Which is why i was wondering if anyone could post or PM any screenshots or code that could help us out.
That probably means you opened up the same reference or something, more than once. It should work fine with the begin and finish VI's, while having your reference and settings in the teleop. If it isn't than you set something up wrong.
Unread 18-02-2010, 18:21
umangv620 umangv620 is offline
Programming Captain
AKA: Umang
FRC #1403 (Cougar Robotics)
umangv620 will become famous soon enoughumangv620 will become famous soon enough
The problem was that Arcade Drive was running in Teleop.vi and Tank Drive was running in Robot Main.vi
Im guessing Arcade Drive is originally in Teleop.vi because we never put it there.
Anyways, we fixed the problem. The error was that the power cable was not properly connected to the Digital Sidecar.
Team 1403 Cougar Robotics
2009-2011 Programming Captain
2010
NJ-Regional - Chairmans Award
Unread 19-02-2010, 12:28
Doc Wu's Avatar
Doc Wu Doc Wu is offline
AKA: Al Gritzmacher
FRC #1507 (Warlocks)
Doc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant futureDoc Wu has a brilliant future
I just read your post. We have been doing the same thing with a servo, but with two preset positions and a button to toggle between them.
Here's a picture of our code:
I put this in a sub-vi, called from teleop.vi. Two controls in teleop.vi are used to set the two angles of the servo. When you get them where you want, either make the current value the default value, (right-click and select Data Operations) or replace them with a constant of the same value. The green, boolean wire comes from the joystick button where it breaks out from the unbundle block.
The Flip-Flop.vi is used to latch the button. I found the VI here on CD a while back, posted by one of the NI people. I don't recall the name or exact post, but it's been quite useful, once I made a few modifications to simplify it for our use.
-= Mentor Lockport Warlocks -=- Team 1507 =-
Amateur Radio Callsign: AE2T
2016 Robot Inspector - Fingerlakes, Pittsburgh
2015 Robot Inspector - Pittsburgh, Champs. Judge Observer - Champs
2014 Robot Inspector - Tech Valley, Fingerlakes, Buckeye, Championship
2013 Robot Inspector - Fingerlakes, Buckeye, Championship
2012 Robot Inspector - Fingerlakes, Buckeye, Championship - Website Evaluator - Fingerlakes, Buckeye, Championship
2011 Robot Inspector - Fingerlakes 2011 Safety Advisor - Fingerlakes
Unread 19-02-2010, 21:52
Programming Captain
AKA: Umang
Thanks, but we have already solved this problem by wiring axis 3 of joystick 3 to the Camera Set Position. It is much simpler code.
2010
HELP- Need Globe Motors ASAP Brandon Holley General Forum 0 03-11-2009 10:37
need help with motors EagleMentor Programming 3 06-02-2009 17:37
Need help with mini motors R.C. Motors 11 03-07-2008 16:25
help getting servo values from camera ruddy Programming 12 30-11-2007 23:18
Window Motors. Need help!!!! Mohsin Motors 1 27-02-2004 13:05
