Go to Post Teams rarely win FIRST events because they can complete actions that nobody else can; they win because they do things faster than others. - Madison [more]
Unread 12-02-2010, 15:24
Kage's Avatar
Kage Kage is offline
1st year junior mentor :)
AKA: Kage
FRC #0238 (Cruisin' Crusaders)
Kage is just really niceKage is just really niceKage is just really niceKage is just really nice
Angry Maybe someone can help me with my...TV?
this morning, my brother and I were watching TV before we went to school, and he went to turn down the volume, but accidentally hit the reset button :|
(this is on our actual TV remote, not the cable box remote, because we got a new cable box the other day, and it isnt synced to change the volume on the tv yet)
the TV company did a horrible job at making this remote, because the buttons along the right side of the remote go as follows:
[on]
[some device slector]
[3]
[6]
[9]
[empty space]
[volume up]
[volume down]
[RESET] <---- WHY PUT THIS RIGHT NEXT TO THE VOLUME DOWN BUTTON!?!?!?
okay, so...
My brother hit the reset button...and now whenever we turn on the tv, it shows a blue screen telling you to plug in all the cables, then hit the [channel up] button...
everything is already plugged in, so I hit the channel up button, and it started cycling through all the ANALOG channels to see if anything was plugged in...
after cycling through channel 1 through 99 twice, it goes to a black screen that says that no analog inputs can be detected :\
ANALOG TV DOESNT EVEN EXIST ANYMORE!!!
anyone got any ideas?
we already tried hitting EVERY other button on the remote. the only 2 that do anything are [channel up] and [power]
and I already tried unplugging everything, and plugging it back in...
nothing
any ideas?
GRAB LIFE BY THE JOYSTICKS!
team member: 4 years
Mentor: soon to be 1
Unread 14-02-2010, 22:02
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Maybe someone can help me with my...TV?
Read the manual? Dunno.
Unread 15-02-2010, 08:31
OK, so you were fooled by the digital changeover. Most cable systems will continue to be analog for many years. They are digital on the cable but that is a different system. Until you purchase HD cable, the box still produces an analog signal most often on channel 3 or 4. The "reset" could be a reset for the cable box or the TV. It is clear that you ran the auto channel scan in the second part of your post. It should only find the cable box if it is turned on. What you may have done is reset the remote. It is likely a programmable remote designed to switch to the TV standard it is used with. If it was given to you with the cable box last week, the installer made the choice for you at installation. The website for your cable system is likely to have a an area to help you learn the operation of the remote and how to reprogram when needed. Check there first for instruction if none were left by the installer.
Unread 15-02-2010, 10:53
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Look on the back of the remote, find the model number and manufacturer's name, and post them.
Or take a picture of the remote so we can see what it looks like.
It's pretty much impossible to help you without knowing what you're working on. The "read the manual" advice is the best place to start.
You can explain how robotics can help with ocean discovery and sustainability. ebarker General Forum 0 30-09-2009 19:01
Can someone explain this to me? B.Collette Website Design/Showcase 7 19-01-2009 20:03
can someone help me with the goals? archiver 2001 2 23-06-2002 23:15
Can someone clear up please? archiver 2000 1 23-06-2002 22:23
