Go to Post Seriously! I expect to follow what I understand to be the intent of (allow teams more time to work with their control systems) and just look out for anyone trying to bring in greater than half a robot. Or a kitchen sink. - petek [more]
Unread 15-02-2010, 09:41
matheus91's Avatar
matheus91 matheus91 is offline
FRC #1860
matheus91 is an unknown quantity at this point
Question Which joysticks/gamepads can we use?
Hi guys,
we are planning to use a gamepad to control the robot but its neither a logitech nor a xbox controller...(see the pic)
and we don't know if it's permitted to use it...I search the manual but there is nothing saying we can't use it...
Can we?
Unread 15-02-2010, 11:13
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: Which joysticks/gamepads can we use?
There are no limitations on the type of controls you can use, so long as none of it violates any other rules.
For example, you could create your very own joystick, so long as it doesn't shine lasers at the other team or blast Taylor Swift songs whenever you turn right.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 15-02-2010, 16:37
matheus91's Avatar
FRC #1860
Alright,
Thanks man...
hehe we certainly won't shot lasers
Unread 15-03-2010, 13:42
rokenboker rokenboker is offline
FRC #1236
rokenboker is an unknown quantity at this point
Exclamation Re: Which joysticks/gamepads can we use?
ho, does anybody know wheather or not wiimotes are allowed to be used? because i know Bluetooth uses a completely different frequency.
Thanks
Unread 15-03-2010, 14:27
<R86> prohibits wireless devices in general, and Bluetooth in particular, as part of the OPERATOR CONSOLE.
(Bluetooth operates on the same 2.4 GHz frequencies as 802.11b/g WiFi. I don't know if things are different this year, but there was definitely stuff going on as part of the field system on those frequencies in 2009.)
Unread 15-03-2010, 14:43
The Lucas's Avatar
CaMOElot, it is a silly place
Thanks
If you are feeling creative, you could make a Wiimote like device with the PSoC (in the kit) since it has an accelerometer. You would probably be a lock for the Innovation in Control Award. If you try this, make sure you have a backup. Our PSoC failed on us during the SF1-2 when the Classmate battery voltage got low, causing us to run the wrong Auto Mode.
Robot Inspector
which motor can we use for the shooter? mahmosh Motors 5 01-02-2009 11:15
which gearboxes can we use for this year? mahmosh Kit & Additional Hardware 2 09-01-2009 19:52
Can we use other joysticks? (was: Question) Sincrum Kit & Additional Hardware 6 09-01-2009 12:15
Which Controller Can we use? THE_SDMC Programming 4 17-01-2007 22:15
What type of joysticks can we use? Wacko324 Control System 11 29-02-2004 10:04
