Go to Post I think that one of the most fantastic parts about FIRST is that the biggest and most successful teams are also the most abiding to the rules. - Matt Adams [more]
Unread 15-02-2010, 10:53
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: clarification of rule <R44> on the "The Robot" section
Surprisingly, part of our robot is going to look very similar - we're stacking the cRio and the PDB as well. However, we're flipping ours around - the cRio is mounted horizontally below the PDB, making the PDB easily seen at all times. For easy access, we've routed all the wires from the PDB to one side - this allows us to run them over a hinge, so the PDB can quickly and easily be raised out of the way for access to the cRio if needed during competition.
If you have the capability to create a sturdy bracket for the top board, a hinge (specifically a piano hinge) might be a great way to go. This will be the third year in a row we've used one. The first year was for a piece of plexiglass covering our electronics and the second year on a sheet aluminum "door" that allowed access to the orbit balls when the robot was turned off so they could be inserted to or removed from our mechanism quickly and easily.
What's the difference between "The Great Attractor" and "Dark Flow" Woody1458 NASA Discussion 0 04-05-2009 22:17
**FIRST EMAIL**/Competition Manual Section 4, "Robot Transportation" Available Now! Tottanka FIRST E-Mail Blast Archive 1 19-12-2008 15:56
Program error - "can not fit the section" miketwalker Programming 9 20-02-2005 01:21
Linking Errors: "section '????' can not fit the section. ..." Astronouth7303 Programming 3 16-01-2005 21:36
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
