Re: Changing gearing
You can do some minor work to one of the end plates, and move the gears around to get rid of the second stage of gear reduction. This will give you a 3.57 (?) ratio instead of 12.75:1 which is quite an increase in speed.
You didn't say what ratio you want....this may or may not help you. |
| Gearing Up! (FIRST documentary) | gearingup | General Forum | 59 | 30-10-2013 03:19 |
| DC Motor and Gearing | Red-Rx7 | Motors | 18 | 22-03-2008 16:35 |
| Gearing Ratios | satyam | Motors | 1 | 31-01-2004 09:50 |
| Gearing Calculator | Gui Cavalcanti | Technical Discussion | 6 | 09-08-2002 10:06 |
| Gearing down? | nerdy | Technical Discussion | 2 | 14-01-2002 00:15 |
