Go to Post The robot is talking to you, you must listen to find out what might be wrong. - Al Skierkiewicz [more]
Unread 02-15-2010, 11:31 AM
nomad725's Avatar
nomad725 nomad725 is offline
Lead Mentor/Drive Coach
AKA: Santesh Shah
FRC #4954 (4-H Palindrome Robotics)
nomad725 is a jewel in the roughnomad725 is a jewel in the roughnomad725 is a jewel in the roughnomad725 is a jewel in the rough
Send a message via AIM to nomad725
Circle Tracker Demo
I am trying to port the demo code into our code when I found out the Tracker demo uses the robot drive class. Anyone have/know how to change this into two independent Jaguar motors?
Unread 02-16-2010, 04:10 PM
BradAMiller BradAMiller is online now
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Circle Tracker Demo
The RobotDrive class will work with either 2 or 4 Jaguar controlled motors. You just need to call the constructor with the port numbers that each of the Jaguars is connected to. You can find the call to the constructor in the 4th line in the CircleTrackerDemo class definition:
RobotDrive drive = new RobotDrive(1, 2);
You can also replace the 1, 2 with two Jaguar objects if that is what you're asking:
Jaguar jag1 = new Jaguar(1);
Jaguar jag2 = new Jaguar(2);
new RobotDrive(jag1, jag2);
Brad Miller
Robotics Resource Center
Line Tracker Mounting Bracket Zuelu562 VEX 0 02-01-2010 08:59 AM
Tracker Code Yellow Eyes Programming 3 02-21-2004 11:14 AM
Infrared tracker Nick R. Electrical 1 02-14-2004 05:24 PM
IR Sensor-tracker.zip alexrobotics Technical Discussion 7 02-06-2004 09:09 AM
score tracker VanWEric Programming 21 01-06-2003 04:58 PM
