Go to Post sweet nectar thy name is Dew... - Trinora [more]
View Poll Results: Did you install the cRIO gaskets included in this year's kit?
Yes 4 50.00%
No 4 50.00%
Voters: 8. You may not vote on this poll
Unread 15-02-2010, 11:41
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Have you installed the cRIO gaskets?
This year, a set of black rubber gaskets for the cRIO were included in the kits of parts.
To install them, you must disassemble the cRIO and apply the gaskets using the procedure at the link below:
http://digital.ni.com/public.nsf/all...257673007935A1
Have you installed yours?
Did you notice your cRIO was dirty inside?
After installing the gaskets did you run into any problems?
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 15-02-2010, 19:47
Re: Have you installed the cRIO gaskets?
I opened up our cRIO and put the gaskets in place. It looked totally clean inside. That's to be expected, for a couple of reasons. First, we had a very nice electrical box last year, which kept out any dust and debris from mechanical work on the robot. Second, it was the cRIO we used on our practice robot, so it didn't see any use in an intense environment.
A couple of students were there to help. We had two observations about the innards of the cRIO. At first glance, it seems like very little stuff for now expensive it is. Looking closer, though, it's impressive how much is packed into such a tiny space.
What are these for? (cRio Gaskets) sparrowkc General Forum 6 01-02-2010 06:41
How do you run the pneumatics through the CRio w/o using the Jaguars and the Spikes brreadd Pneumatics 3 20-11-2009 15:35
Can you get the percent of compression you have? Sean Raia Programming 3 07-03-2009 12:34
You have anything you don't like about the new forums? Ken Leung CD Forum Support 16 16-06-2001 15:37
