SIGNAL LIGHT WONT WORK
the signal light on our robot wont come on, and neither will the tiny one on the digital side car. Can someone help please???????
Re: SIGNAL LIGHT WONT WORK
Have you confirmed your wiring matches both the Robot Power Distribution (with correct polarity) and Robot Data Connectivity diagrams, paying particular attention to the power and signal wires to the digital sidecar?
Is the digital module on the cRIO in slot 4 (with 1 being the slot nearest the lights)? Are the lights green on on your cRIO? Does anything else on the digital sidecar work (PWMs, sensors, whatever)? |
yes all that is done correctly. But the light that is inside the digital sidecar where you need to plug in the signal light is also not blinking
Oh ! I had the same problem last night. Do you have two of the 40 pin sidecar modules? If so try switching the two modules and if it still doesnt work try another 40 pin cable and if it still doesn't work try re-imaging the c-Rio. If it still doesnt work i'm not sure.
Let's try a different approach. Are the three power supply LEDs lit on the sidecar? If not is there a breaker in the PD that is feeding battery to the sidecar? Have you rechecked the wiring at both the PD and the sidecar? It is a frequent mistake that wires at the PD end are not stripped the required 1/2-5/8 inches that is needed for correct insertion. Something less allows a user to insert the wire so far that the Wago will clamp down on the insulation and not the bare wire. Double check that the wire is correctly inserted at the sidecar end as well.
If the battery LED is on and the other lights are not, try removing the Robot signal light from the sidecar. If they come on with the RSL removed, you may have shorted the wiring for the RSL. If they do not come on, it is possible that the card is defective. |
Hi, i am another programmer from 1626.
Please HELP! We don’t know what else to do! Thanks for your help! |
#7
attempt to download the original code to the cRio once again. it should not make a difference as it should not be changable in the code, but in FIRST, sometimes you just have to try anything.
#8
What is the current image name that should be on the cRIO? |
#9
Try picking up your robot, flipping it over, and banging on it, then pick it up and shake it. This will remove all metal shavings, which can short parts of the DSC. We have had to do this twice already on our robot, we know it happens when the +5 light on the DSC goes off and nothing works, but the DSC still has power lights on.
#10
Check to make sure have the Digital Sidecar power wired + to + and - to -. The digital sidecar will function (partially) even if its supply power is backwards, but the signal light will not function in this circumstance.
#12
Peter,
You have tried everything I would have gone through. That really leaves only the side car as being defective. If the PWM signals that pass through are functioning normally and are disabled when the robot is disabled then it can only be the side car. A software expert can answer this better than I but the default code is written such that the RSL functions when the robot is disabled and flashes one of a series of codes that indicate certain conditions on the robot. When enabled, the RSL light should come on solid. "There are four states of this status LED, listed here in order of priority. If multiple occur, the highest one listed is what is displayed. 1. Fast Blink (200ms on / 200ms off) - System error: No driver's station communication, bad cRIO Image, bad team ID, extensive communication errors. 2. Steady on - Everything ok 3. Fast-Slow Blink (200ms on / 900ms off) - System disabled either by system watchdog, user watchdog, or Driver's Station set to disabled and low battery (<12 Volts) 4. Slow Blink (900ms on / 900ms off) - System disabled" |
#13
image v19 would most likely be on your cRio. If you installed the latest update (out since fridayish?) you should currently be at v20 which you will need to do. download and install both the Labview and DS updates. I dont believe that this will fix this problem if you are already running v19, but its a mandatory update non-the-less
#14
Here are the pictures you asked for.
#15
yes samir, we are using v19 when we image the cRIO.
| Dashboard wont work... | nadavsen2 | C/C++ | 2 | 22-09-2012 15:43 |
| Robot Signal Light | smcmahon | Electrical | 20 | 08-03-2009 18:11 |
| FRC Signal Light | railerobotics | Programming | 1 | 07-02-2009 17:01 |
| Signal Light | DustinB_3 | Electrical | 10 | 21-02-2007 13:10 |
| Festo valve.... why wont it work? | CHSguard72 | Pneumatics | 3 | 08-02-2003 19:07 |
