Go to Post Honesty and Integrity is the key to success. - team4384 [more]
Unread 15-02-2010, 11:55
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Very basic programming issue
Here's my take:
Set your PWM cables such that you get the following behaviour:
Forward and Backwards are reversed
Left and Right are reversed
Hopefully when you do this, you'll notice that PWM 1 -> Left and PWM 2 -> Right, just as it should be based on what your code says.
Power down the robot, and on ALL your drivetrain speed controllers, switch the red and black wires that lead to the motors. That will reverse their direction.
Other here might recommend extensive coding changes to make this change in programming, but seeing as how you'd said your programming expertise is low, I think this is your best fix! Just make sure you document that you flipped these wires so that the next person who hooks up your motors knows to reverse them.
In life, what you give, you keep. What you fail to give, you lose forever...
Very Basic: Get a program running on the cRio that will show video on Classmat isaacdl Control System 6 23-01-2010 17:33
very basic code help mikelowry C/C++ 20 18-09-2009 18:38
Very odd issue with WindRiver GGCO C/C++ 1 24-01-2009 01:21
BASIC programming John Gutmann Programming 3 17-05-2005 12:15
Very Basic Programming Question kewlkid382 Chit-Chat 5 18-01-2003 11:11
