Go to Post No one shall stand between me and my sleep. - Adam Y. [more]
Unread 13-02-2010, 20:50
mgamman mgamman is offline
FRC #2869
mgamman is an unknown quantity at this point
Code Not Going to cRIO
I was doing a few tests today and I believe that the code that we are deploying off the laptop isn't actually running on the cRIO. After testing code for the trigger (which did not work), I decided to run some other tests. I decided to comment out everything that was in the teleop method, and then deploy it. Afterwards, the robot still worked the same.
If anyone could help us out, it would be great. Thanks!
Unread 14-02-2010, 14:10
FRC #2869
Re: Code Not Going to cRIO
Does anyone have any suggestions?
Unread 15-02-2010, 04:47
DaSavageJ DaSavageJ is offline
FRC #3011
DaSavageJ is an unknown quantity at this point
Hey I would love to help you, but I need a little bit more information. Maybe if you posted your code or made a more thorough post about what it is your doing.
Unread 15-02-2010, 12:10
FRC #2869
Okay, I will post that information tomorrow.
Code deploys but does not save to cRIO Bill Taylor NI LabVIEW 11 15-02-2012 20:30
Downloading code: Netbeans does not reset cRIO ellisk Java 8 31-01-2010 19:02
cRIO and Laptop Not Communicating ERROR CODE 63 bhavik15 Programming 7 27-01-2010 15:04
cRIO Not Running Code?!? JohnFogarty Programming 11 17-01-2010 19:08
cRIO Not Working?!? JohnFogarty Control System 2 17-01-2010 08:33
