Go to Post Mmmmmmmm. Donuts! - Sean Schuff [more]
Unread 15-02-2010, 12:34
LavaEagle LavaEagle is offline
FRC #2660
LavaEagle is an unknown quantity at this point
Re: Error deploying after building program in labview
It says that it can't save duplicate filenames in the same place, so it moved them to a unique location
Unread 15-02-2010, 16:43
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
This is typically a warning, not an error.
For errors you should scroll through the build dialog message. Also, at the end it will tell you if the build is complete, or if it had errors.
error installing labview error 1335 jerometab NI LabVIEW 0 06-02-2010 18:17
LabVIEW code deploying instead of running linkhyrule5 NI LabVIEW 6 10-01-2010 14:57
Proper procedure for deploying Labview code? domoarigato NI LabVIEW 8 03-02-2009 06:52
Having trouble deploying after update 3.0A Pwolter Programming 1 30-01-2009 21:54
Program error after controller reset randomperson Programming 6 04-01-2005 23:31
