Go to Post In my opinion, watching someone CAD is about as exciting as watching them sleep. - DampRobot [more]
Unread 15-02-2010, 12:18
frcchile's Avatar
frcchile frcchile is offline
FRC #2576
frcchile will become famous soon enough
Fisher Price
Hello to all!!!!
We are trying to hang but with a Fisher Price motor and the gearbox and we want to conect two Fisher Price to one Jaguar, Can we do it?
Thank you !!!
Unread 15-02-2010, 12:22
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Fisher Price
NO.
<R55> A. Each CIM motor and Fisher-Price motor must be connected to one and only one approved speed controller. These motors must not be connected to relay modules.
Joining the 900 Meme Team
FRC #0079
Re: Fisher Price
I encourage you to read R49. In addition to IndySam's comment.
<R49> Each power-regulating device (speed controller or relay module) shall control one and only one electrical load (motor, actuator or compressor).
A. Exception:Multiple low-load, pneumatic solenoid valves may be connected to a single relay module. This would allow one relay module to drive multiple pneumatic actions. No other electrical load can be connected to a relay module used in this manner.
Last edited by Andrew Schreiber : 15-02-2010 at 12:24. Reason: Copy Pasta deleted spaces
Unread 15-02-2010, 13:02
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Fisher Price
If you want to make it easier on your programmers, hook each of the Fisher Price motors up to their own Jaguar (or Victor), then use a PWM Y cable (two should have come in the KoP) to connect both of the speed controllers to a single PWM port on your Digital Side Car. Thus in the code, these act like a single speed controller/motor, and you can be sure they are always being set to drive in the same direction and at the same speed.
Unread 15-02-2010, 14:58
John G John G is offline
FRC #0399 (Eagle Robotics)
John G is on a distinguished road
Re: Fisher Price
You would still need a PID loop to ENSURE the same speed. Without a PID loop, they will not spin at the same rate, causing one motor to hold back/ work against the other motor.
Unread 15-02-2010, 15:07
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Fisher Price
Not necessarily. While it is true that operating one backwards could cause the wiring bias of the Fisher Price motors to cause problems, as long as they are physically spinning the same direction they should be fine. Look at all the teams with four CIM's in their drivetrain, I don't think they have independent control of each of them. Or those who have a CIM and a F-P, they don't need independent control either. As long as they are both going the same direction and geared the same, they will be fine.
Kettering Motorsports
Unread 15-02-2010, 15:30
Re: Fisher Price
Not sure that is the case. As the cost of a motor goes down, so too does the production controls. There are variances motor to motor. Two motors linked in a common gearbox will run together since there is no other way for them to run. You need to feed the same values to each controller to insure that the motors share the load.
BTW, two FP motors connected to a single speed controller would exceed the max current of the controller when the motors are at stall.
Unread 15-02-2010, 20:14
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Fisher Price
I would not run them in a PID control loop. Bad idea.
Do what others have said and run a Y. No reason not to. The motors will run about the same RPM, and even then, the gears make up for it with friction, so each motor is actually working to move the robot rather than working against the other motor.
I would not setup different PWM ports or run them in a PID loop. That's asking for a lot of back-feed into one of the motors. We've fried a Victor before by doing that when we were just moving the robot down the hall. Jaguars will be worse since their fan shuts off when not in controlled use.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 16-02-2010, 02:34
Rohan J Rohan J is offline
FRC #1540 (Flaming Chickens)
Rohan J has a spectacular aura aboutRohan J has a spectacular aura aboutRohan J has a spectacular aura about
Re: Fisher Price
I'm a mechanical guy, but my two years of computer science courses are telling me that it shouldn't be difficult to just make them appear to be one speed controller in software, especially if you are using C++ or Java.
You probably wouldn't want to put them through one speed controller anyways. The maximum current you are allowed to supply to a speed controller is 40A. If the two FP's were drawing 20A each, you would get about 0.25Nm of torque. If each FP was drawing 40A, you'd get 0.50Nm. Keep in mind that an FP stalls at 70A, and 0.45Nm.
Also, my team is using a winch, driven by a CIM and an FP geared to the same speed as a CIM, and there is no PID loop, and since we are using a CAN bus instead of PWM, we didn't use a Y-cable. We're simply telling them to turn at the same time, same speed, and same direction. Seems to be working fine
Fisher-price motor team2061 Motors 14 09-02-2009 12:46
fisher price Futbol.195 Electrical 8 20-01-2008 16:47
Fisher Price Motor Macdaddy549 Motors 5 28-04-2007 09:32
fisher price gears subzero15 Inventor 2 26-03-2007 15:29
Fisher Price Motors MechaJagEric Electrical 3 13-02-2003 08:45
