Go to Post Don't just assume that because you can modify an existing design that you are an engineer. - Daniel_LaFleur [more]
Unread 15-02-2010, 12:05
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
1918 NC Gears Week 5 Pictures
Team 1918 is sprinting toward the finish line (although it's never truly "finished") with a week left before it goes into the bag. It climbs, it turns on a dime, it does flips, it captures the ball anywhere in its wide mouth, it kicks the ball over a bump with the extra-wide foot. We're still working on the lift, cover plate, and decorations.
The kicker uses a linear motion "T-bar" plunger and a hinged flap. It is charged and triggered with a rotary crank. The drive mechanism also releases the mast (not installed yet) and powers the lift winch.
We hope it all holds together.
GO TEAMS!
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 15-02-2010, 12:12
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Re: 1918 NC Gears Week 5 Pictures
Pictures won't display for me...
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 15-02-2010, 13:05
Kyler's Avatar
Kyler Kyler is offline
FRC #1625 (Winnovation)
Kyler has a spectacular aura aboutKyler has a spectacular aura about
Nice looking design. Remember that bumpers are mandatory this year and that could impede on it (successfully) doing flips. If you have managed to get to to do controlled flips with bumpers then good job!
Unread 15-02-2010, 14:26
We still need to finish the bumpers (and secure the wiring).
Our kicker drive was inspired by your 2008 drive wheel & crank mechanism. I never saw it, but it was described to us. We use two sets of ratchets & pawls, oriented in opposite directions to perform different functions, depending on the direction of power shaft rotation.
FTC 6043 & 7911
Unread 15-02-2010, 15:37
GaryVoshol's Avatar
Cogito ergo arbitro
Wayne, those cutouts around the wheels scare me. I hope the wheels don't extend beyond the vertical extension of your FRAME PERIMETER. Hopefully that little extra piece of aluminum where the BUMPERS will attach will save you. The same applies to the axle ends extending from the sides. The GDC clarified the "minor protrusions" are not excluded in Team Updates 6 and 7.
(since 2004)
pic: 1918 Quad Drive Device Wayne TenBrink Extra Discussion 13 24-02-2010 11:50
Team 1918 NC GEARS Robot-VIDEO NC GEARS Robot Showcase 2 16-02-2009 14:03
Team 1918 Progress Packmon_driver Robot Showcase 4 31-01-2006 17:52
Looking for pictures of shifting transmissions that slide gears sanddrag Technical Discussion 3 23-12-2004 07:41
pictures pictures pictures...and more pictures archiver 2001 0 24-06-2002 01:12
