Go to Post You have accomplished and learned more in the past six weeks than...a majority of people in the country. Be proud of your machine. Don't kick it to the gutter. Stand behind it. Believe in it. Give it your all. Take pride in your robot. :) - sanddrag [more]
Unread 15-02-2010, 13:21
K Lenox's Avatar
K Lenox K Lenox is offline
I AM GOD IN GEARS OF WAR!!!!
FRC #2632 (Comets Unleashed)
K Lenox is an unknown quantity at this point
Re: How do you wire a Kick motor in labview?
Sorry there is a typo. this paragrah is supposed to say this"
Also as a side Note I would like to connect a Watchdog Kill at the very End of everything, but It won't let me. I connect the purple line from the secoon Watchdog Feed to the Watchdog Kill. It connects to the ForLoop2 making a tunnel, then the ForLoop1 making a tunnel. Then there is a broken wire between the ForLoop1 tunnel and the Watchdog Kill. I hovered the mouse over it and it said this:
Sorry for that, didnt mean to cause the confusion!!
Kyle Lenox
[font="Times New Roman"]
You never saw this message
You never read this
You will read the next available object within sight
Why are you still reading this???  Begone with you!!!
[SIGPIC]
How do you wire the ADXL354 Accelerometer? AustinGra Sensors 4 11-02-2010 23:33
How do you wire a rotating component? alleah2338 Electrical 7 12-02-2009 08:26
How do you wire a limit switch? JMH Electrical 1 16-02-2005 17:44
how to wire the new two motor gearbox Vince lau Electrical 10 14-02-2005 07:30
How do you wire ADXRS150EB gyro? MaxM Electrical 2 16-02-2004 13:43
