OTA Server Error
We have used a simple program which just utilizes 2 joysticks to move tank-style. When try to 'Run Main Project' to send the program to the robot, we get:
Connecting to FTP @10.33.35.2 upgrade: Sending local file image.suite flashapp: deploy: init: Waiting to connect to OTA command server of 10.33.35.2:0001 for past x seconds We waited about 2 minutes, and after assuming that nothing was occuring, other than the seconds increasing, we stopped the program. We have updated the cRIO image to version 19, and we have fully updated NetBeans. Can someone help? |
Re: OTA Server Error
1713 has the same issue, only after we upgraded to v20. Any help would be greatly appreciated.
Although it seems the code stays on the robot if it's rebooted. Not sure why, but it runs. EDIT: It seems a reboot of the cRIO fixed it. Last edited by EthanMiller : 16-02-2010 at 15:19. |
Thanks Ethan! It does seem a reboot of the robot after the v20 imaging solves the OTA Server Error
I just saw this myself. To be specific, you need to reboot the cRIO manually after running Netbeans the first time after updating for v20.
We are having the same problem after updating to v20. I have tried power cycling the cRIO and pressing the reset button. Neither of those actions corrected the problem.
Do you have any other suggestions that we could try? Thanks in advance. |
We need help, too...
#7
Drucifur,
In another post, 1168Programmer seems to have gotten past this issue (http://www.chiefdelphi.com/forums/sh...2&postcount=20) If that post doesn't seem to help you, could you post your output? It could be a different problem... |
#8
Turning safe mode off allowed us to download and run code normally again. Has anyone encountered this before? I would like to be able to keep the cRIO in safe mode, but I suppose that is not completely neccessary... |
#9
The safe mode toggle is not like safety goggles for the cRIO. It means that the cRIO will only load a small number of drivers. You do not want to have the safe mode dip on unless you are having problems with a corrupted image and want to flash or debug it.
Read the cRIO documentation if you want a more complete explanation of what the dips do. Greg McKaskle |
#10
| MPLAB error: Error [1027] unable to locate 'serial_ports.h' | rokenboker | Programming | 10 | 03-09-2009 16:29 |
| Error in code light on, trouble finding error | Bryan Herbst | Programming | 16 | 12-10-2007 21:59 |
| 180:Error: syntax error help! | seanl | Programming | 8 | 04-02-2007 11:31 |
| stupid Array error: Error [1300] stack frame too l | Validius | Programming | 7 | 27-01-2006 10:53 |
