Go to Post Lengthy posts are not discarded ones. Information comes in all sizes - Garii [more]
Unread 15-02-2010, 15:11
robotic321's Avatar
robotic321 robotic321 is offline
FRC #1793
robotic321 is an unknown quantity at this point
Running / Turning off a Compressor
Hi, we need help with programming a compressor and pressure switch into our teleop code. I am clueless on how to do this and our mentors atm are mechanical ones. Please assist us in this matter. all i need is the compressor to run until the pressure switch triggers. If possible, please post a snippet of a compressor in a teleop code please. Ty
1793 FTW
Unread 15-02-2010, 15:54
Re: Running / Turning off a Compressor
Here's an example: http://www.chiefdelphi.com/forums/at...8&d=1264605003
This code goes in Begin.vi
You'll also want to Close the compressor in Finish.vi: http://www.chiefdelphi.com/forums/at...9&d=1264605002
Unread 15-02-2010, 16:07
robotic321's Avatar
FRC #1793
TYVM from 1793
1793 FTW
Unread 15-02-2010, 16:30
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
You might also check out the compressor examples. From the LabVIEW Getting Started Window, click on the word Examples. In the list you'll find:
Solenoid With Compressor Example
Compressor With Cylinder
These examples also show how to wire everything.
off board compressor legotech25 Pneumatics 10 14-02-2008 20:07
Camera code completely turning off all PWM's Horohoroboarder Programming 10 10-02-2007 19:16
Running just the compressor (was: free compressor) sciguy125 Pneumatics 15 06-02-2006 18:23
Turning motors on and off in the KitGearbox? Andrew Blair Kit & Additional Hardware 4 31-12-2005 10:33
Victor turning off zeep25 Electrical 10 23-02-2004 18:35
