Go to Post Prototype! Always prototype, regardless how crazy! - onenerdyguy [more]
Unread 15-02-2010, 15:23
Alexandstein Alexandstein is offline
FRC #2192 (YAK Attack)
Alexandstein is an unknown quantity at this point
Solenoid actuation problems
We are using pneumatics for our kicker this year as many are, but we are having problems actuating the pneumatics.
Every time an actuation command is given, nothing actuated. The lights on the solenoid light up when the commands are given, so the signal seems to be getting through.
Manual actuation works fine, so nothing is wrong with the actual valves.
Thanks!
Unread 15-02-2010, 15:45
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Solenoid actuation problems
Thanks!
You said lights. Are you actuating both sides of the solenoid at once?
___________________
- Tennyson, Ulysses
Unread 15-02-2010, 15:51
Nope, they are actuating one at a time.
Unread 17-02-2010, 20:36
pschre's Avatar
pschre pschre is offline
Teacher Coach
AKA: James Schreiner
FRC #0806 (Brooklyn Blacksmiths)
pschre will become famous soon enoughpschre will become famous soon enough
Send a message via AIM to pschre
Thumbs down Re: Solenoid actuation problems
We have also been having double solenoid problems, both on the ones we have wired to the Solenoid Breakout and on ones powered off of Spikes and programmed as relays.
The Solenoid Breakout ones:
Solenoid breakout port 1 goes to the B side of the solenoid
Solenoid breakout port 2 goes to the A side of the solenoid
When no buttons are pushed, port 1/B side is lit, and air comes out the A port (we stop this with a T connector looping in on itself so we can get the minimum psi to attempt to switch)
When our assigned joystick button is pushed, the light switches to the other side (both on the solenoid and on the Solenoid Breakout) but the air flow doesn't switch
Regardless of which side of the solenoid is lit, the manual switch buttons on the solenoid do make the airflow switch to the other port.
We swapped in a different solenoid and the same thing happened.
The Spike/Relay ones:
M- goes to the A side of the solenoid
M+ goes to the B side
When no buttons are pushed, the spike is red, the relay light on the DSC is red, we get voltage going out from the M- and none from M+. Air comes out the A port.
When the button is pushed, the spike turns orange, the relay light on the DSC goes green, but we get no voltage from M+ nor M-.
The manual switching buttons on the solenoid do not switch the air.
We swapped in a different Spike and the same thing happened.
Additional info: Both solenoids in the above cases are SMC ones from previous years with 12v fuses.
"In this life we cannot do great things. We can only do small things with great love." -- Mother Teresa
"You give yourself to us, O Lord, then selfless let us be, to serve each other in Your name, in truth and charity." -- Robert E. Kreutz, You Satisfy the Hungry Heart
"You have the right to work, but for the work's sake only. You have no rights to the fruits of work. Desire for the fruits of work must never be your motive in working. Never give way to laziness, either...Work done with anxiety about results is far inferior to work done without such anxiety, in the calm of self-surrender...They who work selfishly for results are miserable." -- from the Bhagavad Gita, quoted in Educating Esmé
Unread 17-02-2010, 21:39
wolvesrobo wolvesrobo is offline
FRC #1780
wolvesrobo is an unknown quantity at this point
my team is using the SMC's i think they are called. if you want to check make sure that on the soloide wiring the M- and M+ go to one side of the spike and then its wired normaly on the other. then you have to combine the black wires and got to the power supply. if it wont work corretly check the programing and the connections.
Solenoid not firing off Solenoid Breakout spooncwru Pneumatics 2 30-01-2010 17:46
Elevator Actuation Sprocket is Slipping JesseK Technical Discussion 6 17-02-2008 09:45
pic: pneumatic actuation of ball valve Andrew Schuetze Extra Discussion 2 30-10-2006 08:40
Building fully flexible tail (several joints) with minimal actuation required sanddrag Technical Discussion 51 27-11-2005 18:05
Mechanical actuation kbrown Pneumatics 1 17-02-2004 16:09
