Go to Post Teamwork has always gotten us somewhere. - Arefin Bari [more]
Unread 10-01-2009, 15:33
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Pnuematic qick connects
They did not give us quick connects this year and the rules seem to say that we can't use it
Items specifically PROHIBITED from use on the ROBOT include:
A.
Any air compressor other than, or in addition to, the one provided in the Kit Of Parts.
B.
Any pneumatic part or component rated for less than 125psi.
C.
Any pneumatic part or component that has been altered, modified, machined, coated, or changed from its original “out of the box” condition, except as required for normal assembly with other components. The only acceptable modifications are:
Tubing may be cut.
Wiring for valves and sensors may be modified to interface with the control system.
Assembling and connecting pneumatic components using the pre-existing threads, mounting brackets, quick-connect fittings, etc.
Can we use quick connects or not?
Faridodin "Fredi" Lajvardi KD7WKD
Unread 10-01-2009, 16:18
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
Re: Pnuematic qick connects
I would think so. I find it very odd that they were not included.
Unread 15-02-2010, 15:36
bailey.berro bailey.berro is offline
FRC #1515
bailey.berro is an unknown quantity at this point
What does "out of the box" directly mean? First doesn't give a definition anywhere in the rule book. Anyone have an idea?
Unread 15-02-2010, 16:39
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
A.
B.
C.
Tubing may be cut.
Yes based on the bolded section of your quote. The following Q&A made it clear that we can use those and flow restricting fittings as well.
http://forums.usfirst.org/showthread.php?t=14515
http://forums.usfirst.org/showthread.php?t=14227
Thank-you 294 & 67
www.bobcatrobotics.org
pnuematic wheels gorrilla Technical Discussion 17 30-09-2008 17:42
efficiency- motor vs. pnuematic BenB Motors 5 01-02-2008 09:46
Pnuematic Claw neoshaakti Pneumatics 4 21-01-2008 14:44
Pnuematic programming f22flyboy Pneumatics 4 11-11-2002 14:37
Pnuematic programming f22flyboy Programming 0 07-11-2002 11:19
