Go to Post I'm not of the belief that this is the intent or purpose of Chief Delphi. It is a place for sharing knowledge and information, perspectives, and humor. In the process, it has created community. - JaneYoung [more]
Unread 15-02-2010, 10:54
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Mechanum wheels?
How are you guys using mechanum wheels driving them?
What on your driver station allows you to turn your robot opposed to translating?
Every day is a new adventure!!!
Unread 15-02-2010, 11:10
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: Mechanum wheels?
We have always used a two joystick setup-
One joystick is traditional arcade drive (forward/backward, turning)
The second joystick is for strafing. Moving that joystick left or right will strafe the robot left or right. The y-axis does nothing.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 15-02-2010, 16:04
the man's Avatar
AKA: Jacob Overla
FRC #4004
Thats different, we are using a 3-axis contoler, the third axis is to turn
Unread 15-02-2010, 21:35
We've got things set up with tank drive, so pushing one joystick forward and the other backward makes the robot turn. Left and right motion on the joysticks makes it slide sideways. We might change this based on driver preference, to put arcade control on one joystick and strafe on the other, the way Bryan describes.
Unread 15-02-2010, 23:02
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
We went with the Logitech 3d Joystick. Twist to rotate.
Unread 15-02-2010, 23:08
Zholl Zholl is offline
AKA: Chris Sherwood
FRC #2996 (Cougars Gone Wired)
Zholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to behold
We're set up with a Xbox controller. The control scheme is similar to your standard FPS game. Left analog does forward/backward and left/right strafe, right stick turns
Team 3070 Mechanum wheels MKenney Robot Showcase 6 05-02-2010 11:25
Mechanum Wheel Rollers Stuck ienjoymycereal Technical Discussion 5 31-01-2010 22:38
Mechanum Code Kory Programming 0 22-01-2008 18:39
Problem with easy c pro and mechanum wheels pbrules15 Programming 9 03-02-2007 20:38
Mechanum Wheels Andy B Technical Discussion 2 10-01-2006 17:41
