Go to Post Team 71: So good at Strategy they already have figured out next years game before the GDC has even met. - IKE [more]
Unread 15-02-2010, 15:04
zoisite117 zoisite117 is offline
FRC #3017
zoisite117 is an unknown quantity at this point
which Solenoid valves are legal?
So my team is using 2 Cylinders for the arm, and this is the first year we do this so we dont know much about this. it seems that we only have 1 five-way Solenoid valve from last year and we didnt get one this yr.
I called Festo to see if they had anyother in stock but it seems they wont till 3/11/10
BUT they suggested part 196925 https://www.festo.com/pnf/en-us_us/p...ist&key=196925
can we use this??
Thank you
Team 3017
Unread 15-02-2010, 15:32
terryo terryo is offline
AKA: Terry O'Brien
FRC #1784 (Litchbots)
terryo is an unknown quantity at this point
Re: which Solenoid valves are legal?
Hi zoisite117,
You should contact your Festo rep and ask if they can provide the Cv. My rep said that the liters/minute flow rate in this size valve will approximately correlate to the Cv, if you multiply liters/minute * 0.001. In this case 350 l/m would approximate a Cv of 0.35.
Also, the max port size is limited to 1/8" npt- this valve port is M7 (> 1/4").
But it should be available in a 1/8" version.
Good luck.
Unread 15-02-2010, 16:16
FRC #3017
Im rather confused about this with flow rates
Do you know a solenoid that would be legal and similar the one provided in KOP
sorry for the trouble.
Thank you again
Unread 15-02-2010, 16:24
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by terryo View Post
Hi zoisite117,
Good luck.
Cv to LPM is not a direct conversion. Get the real number from the manufacturer for that specific valve. You will not be able to compete with an "approximate" Cv.
Originally Posted by zoisite117 View Post
I rather confused about this with flow rates
Do you a solenoid that would be legal and similar the one provided in KOP
Thank you again
Originally Posted by <R72-C>
Solenoid valves. All such valves must have a maximum ⅛” NPT port diameter, and a maximum Cv of 0.32 (if non-KOP valves are used, the team will be required to provide part documentation validating that the valves meet these constraints).
zoisite,
Your valves MUST meet the above requirements (and all other pneumatic requirements in the rulebook).
You'll need a spec sheet on any valve that was not in the KoP to prove that it complies with the above rule.
___________________
- Tennyson, Ulysses
Unread 15-02-2010, 16:39
Jones571's Avatar
Jones571 Jones571 is offline
AKA: Corey
FRC #0571 (Paragon)
Jones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud ofJones571 has much to be proud of
Send a message via AIM to Jones571
As festo doesn't rate there valves in Cv it is hard to bring documentation we will be bringing a copy of this for inspection
http://forums.usfirst.org/showthread.php?t=14677
Unread 15-02-2010, 16:45
Mad Scientist
AKA: Me
FRC #2040 (DERT)
<R33> COTS items from ROBOTS entered in previous FIRST competitions or COTS items that are no longer commercially available may be used under the following conditions:
A. The item must be functionally equivalent to the original condition as delivered from the VENDOR (e.g. a part that has non-functional label markings added would be permitted, but a part that has device-specific mounting holes added would be prohibited), and
B. The item must satisfy ALL applicable 2010 FRC materials/parts use rules.
You'll have to prove functional equivelancy. Without documentation, that may be difficult.
___________________
- Tennyson, Ulysses
Unread 15-02-2010, 17:01
Jones571's Avatar
AKA: Corey
FRC #0571 (Paragon)
How so? The part number approved in that Q&A and is available new from festo we bought 6 new ones for this years bot.
Unread 15-02-2010, 17:06
Mad Scientist
AKA: Me
FRC #2040 (DERT)
The OP was asking about a different part number. The post you pointed to was a specific part used in years past.
___________________
- Tennyson, Ulysses
How to wire solenoid valves???????? JCODER Pneumatics 3 31-01-2008 20:11
where are double solenoid valves placed Reaper40 Pneumatics 5 28-01-2007 15:54
solenoid valves? brian1717 Pneumatics 2 07-01-2007 15:28
Q&A Discuss: Cylinders + Solenoid valves CD47-Bot Extra Discussion 1 05-02-2003 17:21
Cylinders + Solenoid valves Greg General Forum 2 28-01-2003 09:29
